Garage turned into a workshop space
NCD
My single garage is also detached and unheated. Sometimes I work on the car in there using a space heater because the double attached to the house is loaded with crap. As yours, when building the home smart enough to install taller 5 panel rollup doors instead of a 4 panel which would clip the lights on the sports bar but I screwed up with the sideloader option because it is wider than deeper whereas a stock front loader is deeper than wider and with radon pipe box off and steps in original location on the opposite wall, the truck is too long to fit.
One comment on the lighting.....I also had fluorescent installed and they work like crap in the cold and very dim/flicker because the gas doesn't ionize properly in the tubes in cold weather. If not already done, replace with LED tube substitutes usually $12/pr. in Sam's, Walmart or Costco. The LEDs fire up immediately to full brightness.
