Question regarding front axle boots
I just puts a 4" sst superlift lift kit on my 2019 new body silverado ltz z71 4x4. Long story short, I thought I separated the passenger side axle inside the inner boot so I cut the bands and to see what if anything I could do. Well the replacement bands from autozone doesnt get tight enough on the axle. Do I need to buy a new axle? Can someone (dealer) fix this one?  What can I or do I need to do. .. Please help
Dealer may have bands. Mine did the same when I installed my leveling kit and was able to reassemble without issue.
Thanks brianc636 for your response Advance ended up having bands and a crimper that worked.  ...if anyone is considering this lift, I strongly suggest having a heavy duty wall mount spring compressor.  I had 3 of the 2 piece heavy duty spring compressors break on us.  Very very very scary moments.
Kiss your CV's goodbye.  I just had this lift on my truck for a month and took it right back off for a refund.  Angles are too great with no diff drop and/or longer CV's.  CV's vibrate and drone and get worse with time.  I ended up going with the factory GM 2" kit to keep everything covered by warranty.
Did readylift redund your money for the lift?......  I should have waited and seen how other people liked the lift. from everything I had read before ordering it, nobody had any complaints or concerns.
Did you have to replace your cv axles lapoolboy?
Yep.  I went with factory GM 2" instead for peace-of-mind.
    ceeemcgeee
    ceeemcgeee
  • Who's Online   1 Member, 0 Anonymous, 827 Guests (See full list)
