Has anyone added additional lights to the factory bed light switch?  I’d like to add some lights on the rear bumper, and would like them on the bed light switch.
I searched around, but was unable to find a related post.  If this has already been discussed, kindly point me in the right direction.
I was considering doing the same thing.
Yep,
Already did this. I added led lights under the bed rails so I could see what's in there at night under my tonnue cover.  I tied into the bed light switch. You can use the same method to run any other lights you want back there.
Its a simple process, but you will need to use a relay to do it as the BCM looks for a specific voltage on that circuit. Adding more current draw on that circuit causes the bed lights to shut off after 3 seconds.
So I tapped into the bed light as the relay trigger. (top right of photo with the T-Tap) and pulled power from the trailer hitch circuit to run the additional LED lights in the bed. Installed the fused relay right to the body behind the tail lights (bottom of photo) so it would stay dry.
Works well with no issues in 6000 miles of running this truck.
18 hours ago, Smoothbassman said:
Yep,
That looks super clean!  Do you happen to have a wiring schematic I could use?  I was hoping the trailer circuit was adequate for power.
I have done simple light installs in the past, but all have been separate switch and fuse. Tapping into the current circuitry will be a somewhat new experience.
  • 1 year later...
Please share the wiring setup, I installed the 3 piece led strip lights and tapped into the bed light and yes 3 seconds and out. Please share what relay you used.
thanks in advance 🙏
  • 4 months later...
30: hi current 12 volt, install a fuse inline (from battery or trailer plug)
87a: 12volt switched sent to lights being added
86: low current signal voltage (taken from 12volt supply to bed light)
85: frame ground
87: not used
image.thumb.png.a6fa6d31fcc6e71418c6d1644d503311.png30 power from
Looks like the post got cut off on what to hook where. I added the GM light kit for my multi-flex tailgate as well as swapped the lights to brighter aftermarket LED units. I added some 2"x2" LED cubes I had purchased for my Avalanche but never used. The current draw tripped the BCM and they would blink 3 times then go off. I also hooked the cube lights up to the reverse signal so they come on in reverse and at night when the approach lights turn on when you unlock the truck or lock it and leave. I had added a Curt 5th wheel wiring harness expecting I could get my signals from there for what I was originally wanting to do. I found on here that only the 12V+ wire has signal at all times. I pulled the tail light and looked at the wiring. I have LED bed lights in the corners from factory. I tapped that wire on the passenger side(or could use drivers side) and ran that to the 86 wire on a waterproof relay. I added a diode to it so current can't back feed to the bed light circuit. I also tapped the reverse light on the same side, added another diode here so current can't back feed the circuit and added it to the 86 wire. There is a harness that plugs in under the bed and connects to the tail lights. I purchased a new harness to keep as a spare in case I ever had electrical issues that required me to take it to the dealer. I can unplug everything I added and return it to stock. 30 wire I connected to the 12V of the Curt 5th wheel harness I added. This plugs in via T to the factory trailer plug. I have the actual 7 wire plug running into the blank in the passenger bed side where the 120V outlet would be if I had that option. 85 wire can be tapped into the trailer harness ground wire or find a suitable ground wire elsewhere on the chassis or trail light harness. 87 connects to your additional lights. I didn't add a fuse to mine since I'm using the 12V+ from the trailer harness and it is already fused. 87a is NOT used and can be removed or taped off. I heat shrunk/electrical taped up connections and then zip tied the relay to the Curt 5th wheel harness along the tail panel of the bed.
For those not wanting to read it all:
Waterproof relay(as shown above)
30 wire - 12V+ from trailer wire circuit
85 wire - 12V- ground to trailer wire ground, taillight ground, or other suitable chassis ground
86 wire - 12V+ input from LED bed lights and/or reverse lights, using a diode on each input wire to prevent back feeding trigger circuit
87 wire - 12V+ to your additional lights
87a wire - NOT used and can be removed from relay harness or taped off. Not all relays have this pin/wire
  • 1 month later...
That's good detailed information, thanks.
On 1/20/2020 at 4:26 AM, Smoothbassman said:
Yep,
Could you post a pic at night with the latest lluminated?
  • 1 year later...
1 hour ago, ScruffyZ71 said:
Is there no way to make BCM accept the added draw from the LED strips?
No
  • 4 weeks later...
I tapped the trailer 12v circuit and added a door type switch as I didn’t want to have to use the FOB to turn on the added lights. Tailgate drops, lights come on.
  • Thanks 1
Only downside is the lights stay on all the time the tailgate is down. For any reason….No biggie to me but it could be to others…
 Use a toggle switch instead.
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 387 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
