steve8 Posted January 21, 2020 Posted January 21, 2020 My 09 silverado with 70000 miles occasionally throws the check engine light. No real pattern to it. Sometimes its gone the next morning, other times it stays on for a couple of days. Seems to run fine, no misfire, no gas smell etc. Been a great truck and I'm sure this is NBD.
CamGTP Posted January 21, 2020 Posted January 21, 2020 (edited) It's impossible to help in any way without knowing what the check engine light is for. All trouble codes will be stored for a certain period of time. Even if the check engine light just went off the history of the code will still be there. You need to figure out what the code is, then see what the issue may be. Just because you don't notice anything, smell anything or see anything doesn't mean there isn't some sort of issue that you need to address. Edited January 21, 2020 by CamGTP
jrdad111 Posted January 21, 2020 Posted January 21, 2020 Do you know what code it is? Sometimes the seal on the gas cap is not complete which will throw a code. could be as simple as that if you know the code
steve8 Posted January 21, 2020 Author Posted January 21, 2020 Yeah, stupid question. I'll have to have it scanned.
Mitch Marquardt Posted April 23, 2021 Posted April 23, 2021 My 2013 has check engine light intermittent. Code says lean fuel and I've replaced oxygen sensors and that didn't help. Is there something simple so I don't have to pay to put it on a scanner again?
dsr611 Posted April 23, 2021 Posted April 23, 2021 19 hours ago, Mitch Marquardt said: My 2013 has check engine light intermittent. Code says lean fuel and I've replaced oxygen sensors and that didn't help. Is there something simple so I don't have to pay to put it on a scanner again? Need to post the code #... should be Pxxxx (4 numbers after the P). There are several codes that can point to a lean fuel condition. Most places will scan the vehicle at no charge (auto zone, advanced auto, etc) or you can get a decent code reader fairly cheap these days
Register a new accountSign in
