On ‎1‎/‎21‎/‎2020 at 5:01 PM, durandetto said:
We've been installing these on the transit vans like crazy at my work. Haven't heard any feedback yet, but I've been out for shoulder surgery since November. They're designed to be more of a snow tire then the defenders.
Sent from my SM-N975U using Tapatalk
Shoulder surgery is the worse!  Sorry......
It sure is. I broke my leg in 3 places like 5 years ago and the recovery was half the time then a rotary cuff tear. It also hurts a hell of a lot more.
  • 1 year later...
On 1/21/2020 at 5:47 AM, TXGREEK said:
The Michelin Agilis Crossclimate
24be48601cd4e10f3c849e7b8a5a310e.plist0a8e898d118872d143fc00b7c87f0ada.plist
Sent from Above
I am planning to put a set of the Michelin Agilis tires on my '15 Sierra 1500.    They will be replacing my "P" rated Defenders.  My truck is rarely put to work and is treated gently.   Before I purchase, I'd appreciate first-hand reviews/comments from GM Trucks forum members. I am fine with the initial cost but concerned about a noticeably harsher ride and possibly poorer fuel economy.  My only reason for choosing the Agilis over the Defender is the winter designation.
On 10/5/2021 at 5:08 PM, MikeBMW said:
I don't know if anyone here has a real world review, but I did find this:
https://trucktirereviews.com/michelin-agilis-crossclimate-review/
Yes, the reviews on the Agilis don't compel me to take the gamble.  Tires are a major purchase and I want to spend wisely. The Defenders and its predecessors have served me well and I'll likely buy again.  However, I'm the type of person that actually looks at tires on a truck and 20+ years of the same look on my trucks diminishes the excitement of such a major purchase! 😉
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
