Pricey
I can't justify the added cost over the Defender LTX M/S.
Just looked. Not available in my size.
Edited by diyer2
9 minutes ago, diyer2 said:
Pricey
They're like the same price. The one he posted just seems expensive because its a huge 20" LT tire.
Thanks
Still not in my size at Tire Rack.
I have never had Michelins but my next tire will be the Defender LTX M/S.
265/65/18
I posted my size as my OCD with tires has me always looking to compare. Look up your tire size and see for yourself. Michelin Defenders have an enormous following specifically for their long life, ride comfort and great traction. These are the newest design and just as the Defenders were advertised as better for high torque use, so are these.
Sent from Above
Thanks
265/65/18
[emoji4]
You’re not running stock OEM size, you must be leveled running 65 instead of 60’s correct?
Sent from Above
Stock truck.
Tire size is  listed on the door jamb.
Interesting.  I have 71k on my Michelin LTX  MS2's.  Not the Defenders because this tires are 7 yrs old and just now getting down to the wear bars.  Time to replace them.  Rotated every 6 to 7k miles.
It was a little squirrely towing the trailer back home on I-40 in the rain.  Kept the speed at 60mph
They have been on the market for 5-6 month now or more but I haven't heard much feedback about them yet. We shipped out lots of them this winter at my work and even installed a set on one of the work trucks. Probably have 10k miles on them so far and they look new still but I don't get to drive that truck. For sure the target is the heavy duty line for this tire.
We've been installing these on the transit vans like crazy at my work. Haven't heard any feedback yet, but I've been out for shoulder surgery since November. They're designed to be more of a snow tire then the defenders.
Sent from my SM-N975U using Tapatalk
Nice looking tire, but I'm very happy with my Defender LTX's!
My Continental Terrain Contact ATs are very very good.
Take pic and post them.
Sent from Above
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
