Timing Belt/chain?
I have a 2008 suburban 1500 with the 5.3l.
I just past 100k and wanted to know if there is a timing belt or timing chain and when is the recommended mileage to change it?
It's certified for 200K miles and most run way past that.  You'll have AFM and oil pump pick up tube o-ring problems before you have to deal with the timing chain.
Im sure anything can break but from what I understand it is one of those things GM did right.    My old 97' saturn had a timing chain and when I replaced a cracked timing chain cover and had it exposed, it looked like one those things that will highly unlikely fail.   Its covered, lubricated, and is designed for the stress.
I thought about swapping it but it seemed complicated at the time and I wrote it off as if it aint broke dont fix it.
Now the serpentine belt is more prone to damage and should be inspected often
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
