2011 GMC Sierra Remote Start Kit
Steven Tkachuk
I have a 2011 GMC Sierra 1500.  It has the Remote Start Prep Kit installed (AP8).  I've been trying to get the remote start Kit that includes the 2 Key Fobs and Authorization # for GM Service to reprogram the computer, however every dealership that I call say that the Part has been discontinued and no longer available.  My understanding is that this "Part" only contains the Key fobs, and GM authorization code.  I've checked everywhere online, but no one has the GM "Part".  Any help here?
Can I buy the GM Key Fobs elsewhere, and still have the dealer re-program?  It seems Im in a vicious circle.
Thanks,
Steve
You are likely going to have to go aftermarket.  GM does not use common sense where it should be applied.  Back in 2010 I put 4.10 gears in my truck, went to the dealer to have the gearset applied to the speedometer.  Should be a no brainer right?  The techline refused to create the bin file that needed to be applied to the PCM.  Even found a truck on another dealerships lot that had the 4.10 gears and matched my truck completely, my dealer tried to get a new bin file for that trucks VIN, techline refused again.  The authorization number is what is not being produced anymore since you can still get a key fob with a remote start button it.  The authorization number was their way of forcing you to have it installed by the dealer.
Have you checked for the 2way remote start kit?  You may have better luck getting it NOS.  It only comes with the one keyfob though.  The fob eats batteries.  i get one winter out of the 2 batteries it takes.
I have to tell everyone this 1,000 times ... but, YOU DO NOT NEED A DEALER to reprogram ANYTHING!!!
Any competent shop with a good scan tool and/or a J-box can do this for you.
Key fobs are all over the internet. Don't need a dealer for those either!
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
