DU Hookey - Extendable Retreving tool
One of the best mods that I have used with my truck.  Tool is extendable and lets you get items that have moved forward in the truck bed.  Has a tip that lets you go under five gallon jugs an pull the back.  Price for it ranges from 35-40 dollars.  I used panel bond to attach to mount to side of bed rather that drilling to mount.  google it on you tube thay have some other good storage items for your truck also.  Hopes this helps to all
Also how strong is this ?  Like can you pull 200-300 LBS without it breaking ?
Pretty Strong tool made out of aluminum.  If you use your truck bed at all it is really handy getting items from the front of the bed.  As far as the mounting question it came with tow self tapping screws to mount into bed.  Did not want to go this route got some 3M panel bond and mounted it to the side of bed.  Bought one for a contractor buddy said he uses it every day did not  know  what he would do with out it.  Web site say 100lbs it can handel
If you go goggle
Du Ha Storage then go to accessories shows pictures of tool and how it mount in the bed.
