Need some help
I'm swapping in a 6.0 from a 2012 k3500 Silverado into a 2009 Silverado k1500 with a 5.3. I'm also swapping out the 4l60e and trans case for the 6l90 and trans case. Should I swap over the computers for the engine/trans aswell? Will using the computer from the 3500 negate some of the accessories on the 1500? I want to swap out the mechanical fan for the electric fan in the 5.3, and keep some other features on the truck. I'm also camming the truck and I want to install some long tube headers. I would like to use the exhaust from the 3500 on the 1500 because it seems to be a bit larger and I want to do actuall dual exhaust coming out the passenger side of the truck. Will I come into any clearance issues on the exhaust? Also I'm parting out other stuff on the 3500 if interested, it has a large utility box in place of a bed and a nice interior.
That's kind of a can of worms you're dealing with. You can't install the 2012 computer in your truck. All silverado's with the 5.3 use a E38 computer. The heavy duty trucks used the E38 from 2007-2010 only, then they switched to a E78 computer in 2011+ for that body style. The E78 would never communicate with your 2009 correctly and the whole harness is different anyway.
I'd be more inclined to having a shop that does the tuning flash the computer with a 2009 2500HD file as a base starting point. Doing it this way is far easier because you can keep your E38 computer that you must use anyway and just have it flashed to start with a stock 6.0 file that can be tuned from there.
^^^ What Cameron said plus you'll want the cluster and think the shifter too.  Does the 1500 have the K5L HD Cooling system?  If not, you'll want to upgrade the radiator and change the fans and motors from 500 to 700 watts.  The computer for the transmission is inside the transmission, I reckon it would need flashing to talk to the E38 but don't know that much about such swaps.  You could do stand alone stuff from GM or Holley but don't think they'll talk to your instrument cluster.
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
