coolant leaking from under engine
I have a 95 k1500 5.7L engine , I noticed leaking coming from under my engine and I assumed it was the water pump , replaced water pump and it’s still leaking but I can’t seem to find where I assume it’s a freeze plug or a cracked block but I live in SC so it doesent get very cold here and it hasn’t overheated nor have I put antifreeze in it while it was hot to cause it to crack , need more opinions someone help
Any hose connection near the engine, heater hose connections
Intake gasket leak
As you mentioned, check your core plugs for leaks.
You really need to crawl under and do a thorough inspection
