Transmission fluid reading Question
Hey everyone, I'm new to the forum, but a long term lurker so I finally decided to create an account. I have a question that hopefully someone can answer. I have a 2019 LD that when I do a hot temp fluid check, its low. It's actually below the cold mark on the dipstick. I'm doing exactly what the owner's manual says on how to check the fluid. I even took it to one of my local Chevy dealers and they said when they checked it, it was full. The tranny isn't overheating, the fluid is red, and doesn't smell burnt. The truck only has 19,8994 miles on it. Does anyone have any idea would the issue could be? Thanks.
I know this is a stupid question but is there a chance that the ground wasn't as level as their shop floor was when you checked it yourself??
If anything, I'd add a pint or so of fluid and check it again. See where that brings you on the dipstick. It's not going to hurt anything if it ends up somehow being a half quart over full on a 6L80e.
Thanks for the quick response. The driveway I check it in is as level as can be. I live in a very flat area. I forgot to mention I've added a quart of Castrol synthetic blend Dexron 6 fluid, but it didn't make a difference in the fluid level. The truck does shift smoother however. I've checked for leaks around the pan and cooler lines, but there aren't any leaks.
You should get a good reading on a flat level surface, with the engine running and in park with the parking brake on.  If you checked it and it was at the cold level and then added a qt and it didn't change then that is odd, it should have raised the level.  Was the transmission up to temp?
Yup, it would be between 160 to 200 degrees as per the manual when I would check it.
I've never read the manual for checking the fluid but once it's hot I just run it through each gear for 3-5 seconds each while my foot is on the brake. Go from park to reverse, then neutral, drive, manual 1st and back up to park stopping at each again for 3-5 seconds. Then checked the level.
I've done that from park to L for 3 seconds each, but I'm not sure if I've done that from L to park for 3 seconds. I'll try that this weekend and see what happens. Thanks for the help guys.
At least you have a dipstick!
The 8L90 and 10L90 don't have dipsticks!
Just a "check" plug you pull and see if fluid comes out when at temp.
Then there is something different between the methods used between you and the dealer. Investigate that by having them demonstrate it.
I know. I think its ridiculous that transmissions don't have dipsticks. I think all transmissions, regardless if its an automatic or stick should have dipsticks.
I never thought of this. Thanks for the tip.
So I did what you said about going through each range from L to P after doing it from P to L. My tranny is full of fluid. The owner's manual doesn't specify to go from L to P in each range. It says to put it in park after running it down to L. Thanks for your help.
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 733 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
