Has anyone done a self install of Katzkin leather seats on a 19 Silverado? any specific tools needed? how long did it take? any advice?
I installed oem leather take offs I bought on ebay.  They fit perfect with no issues installing them.  I have done a couple other trucks so I knew what I was in for.  Only real snag I ran into was how to unplug the front seats.  I never figured it out so I loosed the bolts holding it down and did them in the truck.  You can google how to do the K2XX trucks and the process is very similar.  On the rear seats the T1 has an upper part of the seat and a lower part.  I would watch this video for better info:
These are the seat covers I bought.  They have a GM part# on each piece so it was easy to match up since there are no instructions.  No special tools needed to install.  Everything these days clips or zipppers in place.  The hardest job to me is the front headrest cover install.  The rear headrests were super easy.
https://www.ebay.com/itm/2019-2020-NEW-TAKEOFF-OEM-CHEVROLET-SILVERADO-CREW-CAB-LEATHER-SEAT-COVER-SET/223803853359?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Edited by lerbud
  • Like 4
Finally had some down tine to complete the install. They came out pretty awesome, and learned a few things along the way!
 I ordered the takeoffs also.  Did you remove the front seats to do the install? Did you try to save the cloth covers or cut them off?  any pointers would be greatly appreciated.
I was able to remove the front seats pretty easily. The wire harness come undone from under the seat by sliding the red release clip back, then pressing Down on the top left corner Of the grey Slide sleeve. Then remove the 4 bolts that hold the seat in and you can remove the front seats. I was able to save all the cloth covers since they are all held on by clips and zippers. The only cuts I had to make were on the cloth head covers along the bottom to get them off a little easier. I just cut the stitching out to help open them up and slide them off a bit easier. Everything else was pretty straight forward. Other than getting in a good hand and forearm work out, take your time and pay attention to detail. I think the top center jump seat was the toughest since you have to remove a parts. Let me know if you run into any issues and I’ll do my best to help with whatever issue pops up.. also, when doing the back seat, remove the top back seat first. It will make getting to the bottom back seat bolts way easier.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
    • I have a 2026 base 1500 "WT" regular cab with basic Chevy "Infotainment 3" 7-inch screen/radio. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit]? [I listen to classical and it gets a bit raspy at slightly higher volumes. Don't need a sub etc.] Do I have two or 1 speakers in the doors? etc. Thanks Bill  San Jose
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
