Does your truck have the Rear Window Leak? - Please Participate! Only voting please!
749 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • 1 month later...
Really wasn't hoping to revisit this thread.  I have a 2020 that I bought brand new, well wouldn't you know it after ~ 5years and 52,000 miles, discovered mine is leaking this weekend.  Couldn't have happened under warranty when I was keeping a closer eye on it after discovering this thread 5 years ago...
My son was sitting in the back and noticed the headliner is stained from past water leaks.  After looking closer, there are cracks all along the plastic trim piece in 3-4 different locations with water stains where it has been dripping down...
I was contemplating taking it back to the dealer and having a new window installed, but sounds like I should try the SEM leveling sealer and 3M strip caulk fix mentioned in this forum by Leevons DIY post.  Since they still haven't changed the design.
Shocked, not shocked to see this is still an issue with the newer trucks.
  • 1 year later...
My ‘19 HC presently at the dealer the last 2 weeks, stated needed new rear window which just got in…quoted almost $3K for the job…new hip replacement so I’m out doing the job myself…GM offered $270 off when I complained even with the TSB…I’m steaming, looking at end of week possibly to getting truck back. This is wrong…no loaner either.
Edited by shakerjoe
Yes, but it's the vent that popped out!!
Look at bottom of rear window, between box and below rear window. Chances are,  a vent popped out! Replacing this is not easy, as the box must be unbolted and pulled back far enough to insert this @#$% thing. Thanks GM, for another useless feature that costs us time and money. Water pouring in FFS
  • 1 month later...
New member here, I have a 2021 Chevy Silverado 1500 RST Double Cab with the 5.3L L84 and the 8 speed 8L90 Transmission which I bought almost 2 months ago, back on April 13th 2026 as the 2nd owner, the truck had 35,875 miles on the clock.
I was aware of this rear window water leak problem and I carefully checked the headliner and the rear seats in this truck for any water stains, when I initially went & looked at it and I didn't see any water stains present.
Sure enough, the first heavy rain I was out in, I saw some water drops on the top of the rear seats, but the headliner remained dry.
It wasn't a massive leak, but it definitely need to be fixed, so I wound up finding 2 YouTube Videos, which were very helpful in showing me how to do the job.
One was a video of the actual repair itself, which invloves completely filling the outside top seam of the rear windhield with ATV/Silicone and the other video was a how-to, on dropping the headliner.
After I noticed the leak, which was on a Thursday, I took that very day (Friday off) and tackled the repair job.
Looking at the cab's rear window, I saw nothing obvious that was wrong, so my guess is I had some small hairline crack somewhere in the plastic trim that goes around the cab's rear window, but nothing plainly visible, like the guy in the YouTube video had. Looking really closely, I could see some old water drip-streaks coming down the inside of the rear cab window, but you had to look really hard to see them, but again, no obvious cracks in the plastic trim around the rear cab window were visible.
It took me about 9 hrs from start to finish, but I was really taking my time and being methodical about it, trying to ensure that I didn't break anything while tearing the interior apart so I could drop the headliner to get at the nuts & bolts that hold the third brake light assembly to the rear of the cab.
All things considered, the job went pretty well, albeit time-consuming and tedious.
But it fixed the leak, so it was time well spent and I fixed that problem in very short order and don't expect that it will EVER be a problem again.
Somebody that's more familiar with how to drop a headliner and who's more mechanically inclined, could easily shave 2 or 3 hours off the amount of time it takes to complete this job.
Like I said, I was really trying to not break anything while taking the interior apart.
These are the 2 videos I used for guidance;
While the video of the repair itself was useful, it didn't go into any detail about how to drop the headliner, so the 2nd video was really key, in getting the job done.
Hopefully, this will help some folks.
Edited by Silver Yeti
  • 4 weeks later...
Glad you had success with it. I did as well, but about 5-6 months later it returned. Tried again, same result. This was after the dealer made several attempts and never even got it to slow down.
    • Oil pump noise was discussed before.  I will try to remember to record a remote start later this morning.
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • On my wife's 2020 Blazer (~69000 miles), we started to notice the brakes pulsating at faster speeds. Typically around town you don't notice anything, but highway/interstate driving you will notice it. I decided to pull of the front tires and look at the brakes. I figured with the milage, the pads should be wearing out to their life span, but they actually looked decent. Still with "meat" on them. One pad has a ridge wearing in it, and that same rotor is showing the ridge too. That's not the concerning part...the other rotor appears to have a raised bump on it!  The picture make it look like a pimple! Very odd and strange! NOTE: These are the factory brakes and rotors.   I'm attaching pictures of the front brakes and what they look like ate ~69000 miles.
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
