I purchased an Opt7 Footwell Light kit that I'm going to install in the 2019 Silverado. I have been following a few threads on how to install the lights, and have gotten the basic install down for me to be able to control them remotely, however, I cannot figure out the door light feature. Does anyone know where I can find the hot wire that activates when the door is open, or conversely when the dome light some on? I need to tap into one of those two wires to get the light kit to operate when I open the door, but I absolutely cannot figure out which wire is the correct one. Anyone done footwell lights yet, or know where I might be able to figure out where to find that wire? How would I even go about manually testing for the door/dome activated wire..? Thanks for the help.
Opt-7 Footwell Light Kit
GM-Trucks 2019 Silverado Footwell Light Post
If one image on another forum is correct it should be the 3rd wire in on the white plug under the driver side dash (the plug closest to the driver seat). However, I want to confirm before I tap, as I hate tapping these wires and there are multiple grey wires in that plug...
It's the 3rd gray wire on the white BCM connector.
See the photo where the green wire is going into. e3cc59e296806fd70345971444793a4a.jpg
Sent from my SM-N960U1 using Tapatalk
Awesome, thank you sir! That's what I thought, just wanted to confirm with someone who's already done it.
Another question, where the hell did you mount your LED strips under the dash? I just realized there's not a nice flat place to mount them like there was on my 2012 Tahoe. Just a very crooked metal bar. Interested to see where you put them
Alex,
I am also curious to where to mount the strips?
Guys
Here's how I mounted mine.
Zip ties on drivers side and rear seats. You won't be able to see any of this from the outside as it's under the dash.
And on the passenger side theres a nice spot where you can stick the adhesive to
Just get creative and mess around until you get something you like.
Hello, if I want my footwell lights to come on like my gauge lights, where what power would I tap into?  I would like my footwell lights to dim like my cluster lights.  Thanks in advance.
  • 11 months later...
Hello, I guess the 2021 GMC Sierra changed up things a bit.  I do not have the grey wire coming out of the white plug., Have anyone put the foot well lights on the 2021 truck, if so what wire did you use and the location.  Strange thing is when I disconnect the plug the lights goes out on the dome, but I cannot find the individual wire that controls the light. Help!
The bottom picture is showing brown, pink and gray. You need to use the white connector to the left or towards the seat.
  • 2 years later...
I've read through all the threads I could find on this and it seems most folks are using this method to power them. However I have the opposite question that doesn't seem to be stated on any of them. Do they power down when the dome lights turn off? Plan on doing this in the next few months when it warms up and trying to plan out this mod and others.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
