I recently bought a 2020 GMC sierra Denali, i got it new, about 200 miles on it, I didn't notice until i got on the interstate that at approximately 65 to 85 mph with cruise set on it that you can hear a rattling noise on the passenger side, you only hear it a high speeds, sometimes you can hear the noise over the radio. First it sounded like crickets in there, i was able to get a recording for the dealership a few days ago, It doesn't do it all the time, if you just drove around town doing average speed you wouldn't notice it, but Its on the way back to the dealership, I didn't want them going into the dash to make matters worse. Has anyone experienced any similar noise on their truck.?
I have had the same noise (loud cricket chirp) behind the glove compartment on the passenger side. I have not traced it down as of yet and am curious what your dealership finds.
Sorry for posting so late, but I found that the noise was coming from the right from mud flap, it’s GMC originally equipment, the front screw had worked it’s way loose or it was never tight from the start. I tighten the screw and drove the truck two hundred miles and there was no noise, I’ve been driving it for the past month and no noise, so thank you for the tip.
  • 7 months later...
On 2/12/2020 at 9:48 PM, Moend said:
Check the front mudflaps. Mine were rattling have the GM mud flaps
Any chance you can share a picture of the location of the missing screw? Mine seems to be missing, but both sides are the same.
I can try, mine are the larger ones and they have a screw that goes underneath. And yes both driver and passenger side were rattling
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
