I got the Towing mirrors as a factory option but am considering going to the standard mirrors. Wondering if the wiring harness and mounting points will match up and retain all functions. Anyone have any idea?
Maybe I should ask this another way. Has anyone replaced their standard mirrors with OE GM Towing Mirrors? If so did the harness match and everything work?
FYI I have a 2020 Silverado HC
2 hours ago, michael betz said:
I have stock. Looking to buy the towing. I'll trade ya!!
Have you checked or read where someone has swapped successfully? I've got just a handful of miles on my 2020 so I'm going to give them a little time to see if I get used to them. Someone else on here said they eventually got used to them.
I'm guessing with yours being the Trail Boss it doesn't have the Technology Pkg/cameras?
I will keep your offer in mind if I decide to change so stay tuned in and maybe drop me a message later
Edited by ArTurf
GM has not offered the power folding tow mirrors as an accessory yet,  so it's really a guess  as to what is required.  The only way to get power folding tow mirrors right now is a upper trim level truck with the Technology package, so you'll have to find a equally as equipped truck to swap mirrors and door harnesses to test it out.
Didn't figure I'd find anyone that has done it but you never know until you ask
There was 1 guy on one of the other posts that claimed that they did the swap around to give him mirrors from another truck when he bought it
I asked if they could swap them when I purchased my truck, but the dealer could not find any official documents stating if it could be done so we left them on.   Beyond the physical installation they thought there would need to be some reprogramming because of the cameras etc.
for sure the technology package would be required (on both trucks)I would think.
  • 5 months later...
Bringing this thread back up. Still wanting to swap back to regular mirrors but don't want to lose any camera functions. One thing on my 2020 that the 2019 doesn't have is the rear side view when towing a trailer and the turn signal is on, really like that.
Anyone made the swap back to standard or vise versa successfully?
I'm open to trade if I know it will work without losing anything
Here is a link to the power-folding mirror update...
Edited by Bobber
You will lose side camera visibility swapping mirrors, there is no way around it.  Swapping mirrors is not supported by GM unless you have the basic mirrors that do not power fold or have safety packages.  Sorry to tell you, but you're stuck with your tow mirrors if you aren't willing to sacrifice your 360 camera.
Is there a way to get the factory software (safety, cameras, etc) for the standard mirrors if you swap? Or is that not the issue? Ordered a truck and I didn't see these things in the build sheet. Not super happy as the dealer my mods on before confirming...
I‘m wanting to change from standard mirrors to the tow mirrors. They are manual (not power folding) but I do have the Safety Package I which has the blind spot monitoring.
I get that the tow mirrors don’t support the safety package. But I guess I’m wondering, can these still be installed on my truck if I’m okay not having the blind spot monitor?
Would the lighting on the tow mirrors still work?
thank you
thank you
Yes the mirrors will bolt up and plug in to your trucks existing harness.  The mirror lights will not work unless you upgrade to new door harness that have the proper wiring.
What I don't know is if you will get any errors on the truck by getting mirrors that delete those features.  I doubt it, but I can't say for sure.
  • Thanks 1
