I've literally been across the country in my truck, and driven through all geography this country has to offer.  The led lights in these trucks are excellent.  My previous vehicle was a Saturn Outlook.  It had HID projector headlamps.  They were good, too.  Only complaint I have about the Silverado led lamps is how high they are.  I feel so bad for the cars in front of me when stopped at a tree light at night that I turn off my headlights until the light turns green and they get going.  I've noticed my lights are blinding the driver via their rear view mirror or side mirrors.  I watch then mess with the mirrors or put their hands up to block the light.  I wish GM would use the current technology on the trucks to turn off the headlights when the truck is at a complete stop and there's a car stopped a few feet in front of you.  The tech is already there.  Just need to integrate it appropriately.
On 8/16/2021 at 4:32 AM, It's Tim said:
I've never realized so many people have night blindness.
Vitamin A deficiency.  Mom was right -- they should've eaten their veggies.
Coming from a 2010 Toyota Tundra with retrofit HIDs, these lights are considerably better. My drive home from the dealership included some two lane mountain roads, and I could see everything in front and to the side of me. If I wanted more, turned on the brites. no problems. I did have a few people flashing their lights at me as they thought I was driving with my high beams on. I let them think I was a jerk, because I didn't want to cause an accident by flashing my high beams at them and freaking them out.
I am now a little concerned about how long the lights will last. Obviously, we got at least 3 years as 2018 models have been around for a while and I don't see anyone complaining about having to replace a HC or Denali head light. I would imagine we're probably around 5 years life expectancy, hopefully by then we'll have something figured out.
One of my fog lights on my 2020 anyway burned out, but it was replaced under warranty.  Truck wasn't even a year old at that point.  New one are $150 because they're also LED.
I've seen a few fog light kits on different sites, but yeah, warranty would be best. I wonder if a sealed headlight going out would be covered under a bump-to-bumper since it's not a maintenance-able part....hmm. I wonder.
  • 2 years later...
On 6/18/2021 at 1:15 AM, msaul37 said:
i figured when i traded my '14 silverado that the LEDs would be night/day difference, but other than the 'color', that's all i've seen. I do half of my driving at night, so i need to have more vision down the road for suicidal deer.  I'm afraid the only way to upgrade them is to get entire headlight replacements.. housing and all. I also don't like how focused the beam is. I don't want to blind oncoming drivers, but if something like a deer is 5 ft to the side of the truck, about 50 ft away, I can't really see it.
I have the same problem. I had to install a pair of Lasfit pod ditch lights to solve the problem with my 2019 Silverado RST. I already hot one deer last year up in the mountains where I live. I also installed the Rough Country grill lights. Good luck.
" I will not purchase a Toyota, because I only buy American, but I will only purchase older GM vehicles from now on
The tundra is probably  more American made than the Silverado.  The Tundra is made from 60% domestically sourced parts with only 15% coming from japan.  The Chevrolet is made up of 62% of its parts sourced from US and Canada.
They are covered under warranty, ive had the drivers side replaced twice now on my '22. But dealer did warn me that if it happens after 36k mile bumper to bumper its $1200 out of pocket. so im not looking forward to that!
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
