I just bought a 2014  Sierra 1500 Z71 double cab with 95.000 miles. Saturday I went to get my hair cut and after got in my truck to leave. It wouldn't start. I keep a scan tool on me so I scanned it and no codes. Everything would turn on and work just no signal to the starter. I call onstar for towing and I'm sitting there randomly trying to start it. Putting it in neutral, cycling the locks all the old tricks. I open the hood, check the cables and everything is fine. Go to start it and boom started right up. I drive right to the only dealer who's open and they determined it was the license plate LED lights and they should be normal lights. Dealer tells me that's all and sends me on my way. I go to start it to leave and once again it wont start.  They scan it again and determine the chassis control module was not communicating for some unknown reason. I leave it there and all day yesterday and today its been starting just fine. So I guess I am going to pick it up tonight.  I don't like the idea of rolling the dice every time I go to start my truck.
Anyone experience this or have an idea? Dealer is clueless.
So what did the dealer say it wasnt communicating too. For instance, I had a no communication fault (U1556) but it was for the trailer brake module not communicating. This didnt stop the truck from being able to be driven. So I am curious what communication fault they found.
Sent from my SM-A505U using Tapatalk
Why would the LED lights matter?
I too am having electrical issues with a 2019 Yukon.  At the dealership twice now.  "Rolling the dice" as you say.  If there aren't any codes stored they don't investigate or diagnose, they just send you back on your way until it happens again.
Edited by BlaineBug
Well, at first it was "license plate bracket" and circuit had feed back and was interrupting the BCM/CCM. So I pulled the LED lights at their recommendation, I did not have the code for that. For those asking about LED lights, this model and up the electrical system measures the resistance of ALL the circuits. When not equipped with factory LED and you switch over it can cause "feedback" or resistance issues. I've heard of this before but with the quality of GM and all the electrical issues the LED lights carry no resistance compared to your normal bulb, therefore there can be power to other grounds in the system.
But back to my truck, after the initial license plate bracket feed back issue I pulled the bulbs and it wouldn't start. Then we got a ccm communication issue, not communicating at all (I don't have the code for that). The following day the truck was starting great but pulled a HVAC communication code U0140, the controls worked fine. Today the truck is working fine.  I personally think there's a ground issue or something shorting and feeding power to the grounds of the truck.  I live here in Lansing MI where there is a ton of GM plants and suppliers. If I told you the personal first hand stories I have heard about quality control issues you guys would freak.
 I've had newer Fords for the last 8 years and never had any of these issues. I loved the look of the GM and was trying to save a little money as I just bought a house. The fords are priced higher so I gambled with the GM. If this does it again and the dealer cannot figure it out, I am going to go attempt to "tune and delete" what I can so the drive-ability is basically standalone relying on the ECM only.  I love the look of the truck and it seemed finally GM stepped up their build quality but it appears to be the appearance only.
My background, I used to be a certified technician (Not GM factory trained). I've tuned and ran stand-alone ECM's for older 1st-2nd gen 5.3s.
there was a post about led lights, i think it was called my 457 dollar mistake. apparently these truck do a diagnostic check on lights when you shut it down. the led lights dont return hte correct answer to the check causing the module not to go to sleep and it drains the battery
Very strange.  How were the LED bulbs at fault if your truck had issues again when leaving the dealership the first time?  I'll be PMing you shortly.
Edited by BlaineBug
If you pulled a U0140 that is a communication fault with the BCM a U0164 would be HVAC. The U0140 can stop a vehicle from starting especially because of the anti theft. I would scan truck everyday for a few days. If you keep getting U0140 then you might be having a BCM problem.
The paper from the dealer said U0140 loss hvac loss to BCM but, noted for future reference. I'll have to see if my buddy can scan it with his scan tool. Mine only pulls engine, ABS and SRS
U codes are history codes aren't they?  One of the service advisers where my Yukon sits on Friday said "those really aren't codes" or something along the lines of them not being codes worth paying attention to?
I remember when it went in for the first time it had three history codes (U0100, U0121, & U0422) and once again they said history codes didn't mean much because they could have happened anytime and who knows when and didn't help them diagnose it at all.
Edited by BlaineBug
I remember when it went in the first time it had three "history" codes and once again they said history codes didn't mean much because they could have happened anytime and who knows when.
Anything U coded is Electrical. They are most defiantly real, and they are a real pain in the ass.
Genius service advisers then.  How lovely.  I feel as if a lot of these people in automotive tech customer service don't have the first clue about automotive tech.  You can just tell through conversations when they go silent it's a defense mechanism rather than just telling you "You may as well be speaking gibberish, sir."
Is it possible to acquire a fresh U code without a check engine light coming on?  Because that is one thing that hasn't turned on to alert of a fault, even when my vehicle's failures have been active!
Edited by BlaineBug
This may or may not be related as there are so many ways a system can fail but the comment about a failure to communicate with the chassis control module is/was part of my issue.  I've had a serious problem lately with my 2016 Silverado dying on me but it usually throws up a bunch errors starting with Service Trailer Brake and Stabilitrac Off,  before going into limp along mode and then eventually just packing it in, though the engine continues to run but the tack drops to zero.  Once I shut it off it will not re-start however at one point when it wouldn't start I disconnected the EBCM (ABS) and it started. I reconnected it and it wouldn't start (suggesting the issue was the EBCM or the CCM or the wiring in between).  There is also a clear correlation between this happening and wet sloppy Ontario roads. Twice I've had it towed to a dealer and what they've found is a slew of communication errors between all of the devices on the main GMLAN which includes the ECM, TCM, TCCM, Telematics module, HMI module, Body Control Module, PSCM, EBCM and finally the Chassis Control Module. Unfortunately however by the time they've taken it into the shop, it runs and there are no active faults. Two dealers spent a combined 14 hours pulling apart wiring harnesses starting where they go through the door sill all the way to the chassis control module and found nothing. They said it's almost always a small nick in the wire with signs of corrosion around it. Eventually I got tired of paying big bucks for someone to unwrap wires so I took it home and started pulling it apart myself and checking the wires inch by inch very carefully. Eventually in a section just in front of the left rear wheel I found what is almost certainly the culprit, exactly as described. The nick was in an area that neither dealer had touched I suspect because it's such a pain to get at. In my case the wire wrapping had loosened up and the wrappings had filled with mud and salty water but I suspect subsequently drained out upon sitting allowing the communications to resume. Appreciate that the network operates between 1 and 3 volts so pulling it down doesn't take much. As of this morning I have it all back together and no fault codes. Fingers crossed that I've fixed it. It's just started snowing so tomorrow will be a good day for a test drive.
Edited by Timmer66
Picture too big
This is super interesting. If I start pulling more codes I may touch base with you and dig further.
HELLOOO!!!!!!       Why is so hard for everyone to believe that the vast majority of service writers are idiots. They are!
There are lots of U codes that will not set an ECM code turning on the SES light.
It's not hard to believe.  But then again there are other "entry level" positions out there that require so much experience and knowledge.....you'd think having a basic understanding of automotive tech would be a prerequisite to dealing at any position within the service department.
@tbarn I will be private messaging you as well.  Your information about tachometer reading nothing while engine running intrigues me.
Edited by BlaineBug
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 1,298 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
