Which UCA is this?
6 minutes ago, swathdiver said:
Plug your VIN in here and have a look, have your RPO codes handy:
https://parts-catalog.acdelco.com/catalog/catalog_search.php
Did that, got this:
Cast description:
Suspension Control Arm and Ball Joint Assembly
All; Front Right Lower; Cast Iron Arm; Except RPO AVV Mid-Year Model Change; Will Not Fit Aluminum Steering Knuckles; Except RPO Code AVV MID-YEAR MODEL CHANGE; Without ALUMINUM STEERING KNUCKLES; RWD*; All; Front Right Lower; Cast Iron Arm; Except RPO AVV Mid-Year Model Change; Except Off Road Package; Will Not Fit Aluminum Steering Knuckles; Except RPO Code AVV MID-YEAR MODEL CHANGE; Except OFF ROAD Package; Without ALUMINUM STEERING KNUCKLES; 4WD*
Per Vehicle: 1; Years: 2016-2016
I do not have an AVV RPO code in the truck or on the build sheet.
Forged description:
All; Front Right Upper; Forged Steel; Without ALUMINUM STEERING KNUCKLES
Per Vehicle: 1; Years: 2014-2016
Nothing really definitive, but I'm thinking they're the forged arms
cast steel, (looks like a cast iron pan), Aluminum is shiny silver pretty easy to distinguish, and stamped steel is shiny black and smooth and looks more boxy.
3 hours ago, 14 Silvy said:
It’s the cast steel control arms.
Thanks guys! That's what I thought, but confirmation is always appreciated.
