I'm going to install a dash cam on the front windshield in the next few days and I'll be running a power wire down the passenger side A pillar to the passenger side fuse box. I'm not sure how much trouble it will be to access the fuse box from under the dash.  The run from the bottom of the A pillar to the fuses isn't far, so it shouldn't be too difficult.  Just wondering if someone else has done this and might have some insight as to the best way to get into the fuse box from the bottom of the A pillar.  Also, any advice on what switched fuse location would be best for a camera.
I ran my wires to the top of the fuse box. There’s access to the top from behind the A pillar molding. Not even sure how’d you access it from the bottom when the fuse box is directly under the A pillar.
I have my camper rear vision camera wired up- but I used this lug on the passenger side.  It's easy to get to and a spade terminal plugs right up.  It's retained accessory power too.
The power in the driver's side box is all constant hot (I believe) if you want that.
Hope that helps...
Yes, that does help and thank you!  I pulled the dash end off earlier today and it looks fairly simple to pass into the fuse location.  The camera should arrive on Monday - we'll see how it goes.
  • 5 months later...
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
