36 minutes ago, MTBR said:
Loving it. I installed the 1.25" BORA spacers, removed all the mud/aero flaps, removed the liner brackets, and used some self tapping screws to pin back the liner. Just the slightest kiss on the liner at full lock.
Also installed the Rough Country in-line speedo converter.
Got my eye on those Eibachs now...
Nice! Yeah these trucks look great with the 35s and 1.25 spacers. Just enough to give the stuck an aggressive stance but not too extreme.
The Eibachs are a great choice. Let me know if you have any questions on the install if you get them.
Well I finally got my new wheels and tires. Here are a few close up shots. I had to drive 2 hours to find a shop to swap the TPMS from my factory wheels...covid.
I went down to 17x8.5 to try and save some weight and get more tire sidewall. 35/12.5. I like the simple design of these wheels, nice and clean with a lip but no fake bead lock ring/bolts. I love the bronze it reminds me of JDM rally STI wheels. I had Mud Tires on before that looked great but lacked in performance. The tires were obnoxiously loud, vibrated a lot on the freeway over 60, but the worst part was having to dig gravel out of the tread every day ( I live on a gravel road ). The Toyo R/T’s are impressive, smooth as silk on the freeway and almost no road noise.
I’m running the 1.25 spacers right now but I think I’ll remove them because the 0mm offset already gives the wheel plenty of poke. Anyways I’ll post some full truck pics once the weather clears.
Decided to remove the spacers, I was getting a noise in the front end and it was the front driver side spacer, one of the bolts came loose somehow I triple checked the torque and used lock-tight on the studs. I was planning to take them off anyways because the new wheels at 0mm offset have the perfect poke with the stock fenders. Also cleaned up the front end and lost the white lettering in the grill and the rigid fog lights, my led headlights have plenty of light and don’t blind oncoming traffic. The bumper caps clean up the bottom valance. Makes the red hooks pop more. Build has been slow But will continue...
  • 5 months later...
Cold start with the flow fx catback. Love the 5.3 just wish it was more tunable.
how do you like the eibach pro truck?  been eyeing it for a while...but just havent saved up for it just yet...did it take a while to get settled/broken in?
Added some AT4 style pocket fenders...was looking for something really clean and oem. These are stainless steel painted in a semi flat black finish with a really tight rubber seal. More pics of the whole truck soon.
I Love them. Haven’t felt much break in difference since I put them on. They are much stiffer then stock but I wanted that so objectively they’re exactly what I was looking for.
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
