Borla or Corsa
I am wanting to order a new exhaust for my AT4. I’ve always been a Corsa fan and have had it on several previous vehicles. Looking at their system I’ve seen a couple negative things said but also saw similar of Borla. If I ordered the Borla I think I would get the ATAK but am not totally sure. I understand this is subjective but I don’t always trust videos either as the editing and speaker quality plays a part. Has anyone by chance heard both? Or if y’all just want to give me your opinion I’m all ears.
I'm considering a Borla touring for mine. I'm worried that these new 10 speeds are going to make for a terrible drone in the cab on the highway and towing.
I'm interested in finding out which one you go with. I've always been a Flowmaster guy but the Corsa and Borla exhausts sound pretty good on these things.
I have the borla atak and I love it.  Here's a clip :
Just had the Borla Touring installed on my AT4 last week and absolutely love it. No drone whatsoever when driving. Was considering the S-Type and the guy who installed talked me out of it since it’s my everyday ride.
Borla S type on my 2020 AT4. Love it. I run a Corsa on my 07 H2, but I’m even considering switching that to Borla.
Here’s a quick clip I’m of before and after.
 https://youtu.be/iNu9w1a7dl0
I’ve never had a Borla but I’ve never had a Corsa that drones. I’ve also never heard a Flowmaster that didn’t lol my dad has one on a Corvette that was so bad he now refuses to put an exhaust on any vehicle because the drone was so horrible. Whichever you pick will be better than Flowmaster.
I’m leaning closer and closer to the ATAK by the minute, thanks.
How is the ATAK in the cab? Fairly noticeable when cruising or no? Obviously I know you really hear it when you get on it.
Borla is hard to beat.  This is my 2nd truck with their system. Also have an X pipe on my Grand Sport.  Very happy with them.
Honestly, i was worried about it being too much at first, but i don't even notice it anymore.  One thing i will say though is i know when i start it up every morning at my apartment complex, everyone can hear it lol.
Haha fair enough. I don’t drive mine every day, so as long as it isn’t too loud in the cab when cruising I don’t care.
