2000 gmc yukon xl 6.0l nose dives in overdrive
Josh Cease
I have a 2000 gmc yukon xl 6.0l 4x4 with 238,000 miles but motor was rebuilt 50,000 miles ago just started acting up and it runs smooth and I was cursing doing about 60 and gave it gas and as soon as it hits overdrive its nose dives and loses  power and  It doesn't feel like it's the transmission it acts like either the CPU  or throttle body just goes stupid but you can left off the pedal and press the pedal back down and it drives fine ??? Just acts up when trying to pass or putting pedal to floor ? I've done a tune up and all I dont know what else it could be ?
There are two things to look at, fuel pressure and catalytic converters.  A plugged fuel filter will behave this way, and if you don't know when it was last changed, now is as good a time as any to replace it.
A plugged catalytic converter will also behave this way.  You may find the exhaust is quieter than you remember.  Depending on how plugged up it is, flooring the gas pedal in park may cause the engine to simply not go past 2 or 3k rpm.  Do not hold the pedal down any longer than a second or two.  If it is plugged you will see it right away.  If you park your truck next to a wall on the passenger side, rolling down the passenger side window will allow you to hear the exhaust sound while doing this.  If the converter is plugged it will have a hissing sound, almost like compressed air.  If you put a fuel pressure gauge on the fuel rail and if the filter is plugged, the fuel pressure will drop off noticeably.
The cats were taken off completely new exhaust from front to back  and the fuel filter was changed about a week ago its it weird how it does it .when its does it the pedal pulls away from my foot and sticks and loses power but if you tap the pedal again it will start driving normal again until you try to accelerate
Make sure there's no mouse motel in the airbox, or in any of the intake hose to the throttle body. Make sure the MAF isn't all coked up with crap, especially if running an air filter that requires oil, like a K&N.
If that checks out, you'll need a fuel pressure gauge next. Need to know the fuel pressure running, and on a snap-throttle. If pressure dips on a snap, you need a pump.
You could also have a throttle body issue going on there. Pedal should never stick.
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
