Here they are, they measure about 27” across but I have a 3” lift so that will make them a little longer and a little dimmer on the ground. The pictures were taken in my garage, I have garage door windows and a double window on the side of my garage so it’s pretty bright in there and they still show up nicely. It was about 1 minute per side, all you need is a small flathead screwdriver to pop them out, super easy.
Nice I didn’t think they would be that bright
congratulations they look great
Can you post some pictures at night. Also could you post a pic of how it looks with mirrors closed. Wondering if they would still look ok with mirrors folded in. Thanks
Still in the garage, headlights came on but otherwise no additional lighting. Obviously when the mirrors are closed they are worthless but since I rarely fold them it’s not an issue for me.
GMC brand is on back order
According to the email I got today
I order them right from the GMC website
Cant wait to see GMC, thanks everyone
I have to say I'm pleasantly surprised at how nice these OEM lights are. I have a 2017 Audi Q7 and the OEM puddle lights showing the Audi Rings were not as bright an they were mounted under the door.
How dark was it when that second picture was taken
Not that dark the sun was starting to come up. So not bright but not dark. Was surprised I could see it. But at night the light is very bright
I just installed during the day and couldn’t see the light now that the sun has set they look greatbd58f394816b95ee2172c73f7e2a5b03.jpg
Now the question is do I do the illuminated emblem
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 440 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
