Just installed ford t-bar keys
We put them on a friend's Silverado extended cab. Holy cow, what an easy job. Took us about an hour. The hardest part was getting the factory keys off the t-bars, just because they had some sand and other junk in there, and still that wasn't too hard. He ordered ford part number XL3Z5B328CA (received them the next day from the local dealer) at a total cost of $48 something for the two keys. His fender measurements before were 35 1/2 inches (measured from the ground to the bottom edge of the factory fender flare in line with the center of the wheel hub). After installing the ford keys and adjusting to where he wanted them, they measured 37 inches (same as the rear) and his truck now sits level. He's off this weekend to add some 285/75-16's.
Tom,
How much did 1.5 inches stiffen up the ride? Would you have to install the Ford keys to just go 1.5"? I've been thinking about raising the front of mine a little bit, but I'm afraid the ride will get too rough.
Thanks,
Tom,
Would your friend be interested in getting rid of his stock green keys? If so I would be interested.
Thanks,
Matt
:lol: What is involved in installing these? Is there a post somewhere with detailed instructions? :D
BTW, I just found this site, looks great too. Lots of good info I've seen so far. Thanks for letting me join in. My truck is '01 Sierra Ext cab, 2wd.
Well, I don't think he wants to get rid of his old one because he said he was going to hold on to the in case something happened and he needed to use them.
I don't know about the ride myself because I didn't ride in it, but he said it felt a little stiffer, but not real bad.
As far as cranking them, it only involves tightening them to lift it up, and loosening them to lower it. The bolt was either 18 or 19mm, can't remember which. His were not even, one side was in about half way, the other almost all the way.
As far as instructions, we didn't take any pics or anything, but I can explain it. I can also set-up a pic with my truck it any one needs one. First we sprayed the adjustment bolts and where the key and tbar meet with WD-40. We lifted the front of the truck and placed jackstands under the frame. This helped get the weight off the suspension. Then we removed the adjustment bolt. We used a heavy duty 2 jaw gear puller attached to the crossmember and cranked in the key in (there is a little dimple ont he key to put the screw of the gear puller in) untill we could pull the cam, pin, or whatever you call that thing the adjustment bolt goes into out of the crossmember. Then we backed off the gear puller until there was no more tension on the t-bar. Slid the t-bar towards the front of the truck until the key came off the back side of it. This was honestly the hardest part because of the sand, rust, dirt inbetween the two, but with a little wiggling it will come off. Then we put the new key on, which will be angled witht he adjustment point a little lower than the factory one. Cranked it back up witht he gear puller, installed the cam/pin thing in, reinstalled the adjustment bolt and only put them in about half way. He drove it around the block a time or two, which made the suspension settle about 1/2 inch. Then we lifted each side and made a few adjustments to get it where he wanted it and he drove it around again to make sure it was settled. He ended up with 1 1/2 inches of lift. He's getting new 285's this weekend, and I think an alignment sometime after that.
:lol: What is involved in installing these? Is there a post somewhere with detailed instructions? :lol:
If you need detailed instruction some one on another forum similar to this one has excellent directions with pictures! Here is a link Ford Keys & Torsion Bar Cranking Hope this helps.
Tom,
Thanks anyways on the keys. I guess I will just go buy me some green keys!!
Thanks,
Matt :D
Hey Stlmaj I just picked up a set of green keys from the local dealer today. Going to install this weekend if everything goes allright. I have the same truck as you, will let you know how it turns out.
Thanks for the info, and the link. :D That looks easy enough. But, I've said that before :lol:
I'll let you know how it goes. Or be back for help!!!
:flag: What is involved in installing these?  Is there a post somewhere with detailed instructions? :seeya:
Tom,
Thanks,
Matt :smash:
Yep, that's pretty much how we did his. :thumbs:
Thanks, I am interested to hear what you think. :thumbs:
Matt
Stlmaj just got the green keys installed this afternoon. Measurements before and after showed a three inch lift with the adjusters set at the same location as the stock keys. truck is a quarter inch higher in the front, 38-1/4 inches versus 38 inches in the rear. ride is a little stiffer but I like it that way. Should clear 285's with no problem now. CV angles look fine, borrowed a tool from the local dealer to unload the tbars, didn't trust the looks of the 7ton pullers the other guyswere using, after doing the install I was glad I did cause it sure made some scary noises loading an unloading the bars. By the way my truck also has the GL bars from the factory. If you have anymore questions email me.
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
    • Engine Wear and ISO 4406   1.) Cold Starts. 2.) High Particle Count. 3.) Low operating temperature viscosity and high low temperature cranking viscosity. 4.) Depleted AW, Friction and Acid packages.  5.) High engine load.    https://me.caltexlubricants.com/en_me/home/learning/from-chevron/heavy-duty-diesel-vehicles-and-equipment/The-Importance-of-Clean-Engine-Oil-and-Its-Impact-on-Equipment-and-Business-Performance.html   High particle counts have five sources. 1.) They are manufactured within the engine. Both wear debris and amalgamation of degradation products and combustion driven soot (worse in GDI). 2.) They are ingested via intake air. Ever hear the best oil filter is a good air filter? 3.) They are entrained in the fuel. 4.) This one is insidious. They are introduced in 'fresh oil'. 5.) They are introduced during the oil change.   ISO 4406 is the test that measures and quantifies the combine effects of all of the above particle related issues. You can mitigate your way into multiples of engine life by being attentive to them all.    https://www.hyprofiltration.com/blog/is-new-oil-clean   (from the link above)    [Quote] What Is the Recommended ISO 4406 Cleanliness Code for New Oil?   A good upper limit for new oil cleanliness is 16/14/11 (ISO 4406). Typical new oil usually has ISO codes of 19/17/15 or worse, which is far too dirty for sensitive components. This can be a major cause of degradation and premature failure. [Close quote].     Source of graph: Machinery Lubrication (GM Study)
