I need help connecting to the Fifth, the # 5, Upfitter power wire in the Center High Mount Stop Lamp (CHMSL).  I would like to power a headache rack mounted light bar from that switch.  I have looked at the Upfitter Bulletin #157, but it does not give me enough information to identify the location to drill in the CHMSL.  Has anyone in the forum done this and can add some advice, or pictures?  Image below is from the bulletin.
Insert other media.url
  • 4 months later...
Boredom overcame the fear of drilling a hole to find the beacon, or fifth Upfitter switch, wirers.  I used a 5/8 drill, the largest I have, and the smallest I would recommend. I started with a 3/8, then stepped up to a 1/2, and finally the 5/8.  I was hoping to avoid chipping the paint, didn’t work, a small hole saw would have done a better job. A 1/4 ID / 5/8 OD grommet hides some of the paint chips, but not all.  The two wires, hot and ground are wrapped in BLACK cloth tape making them very hard to find in the BLACK hole.  The pliers just slipped on the cloth tape, the brake spring hook worked much better.  I included a link to the Upfitter bulletin and a few photos.  Switch number five now powers a 52 inch light bar.
https://www.gmupfitter.com/files/media/photo/1329/UI Bulletin_157.pdf
Edited by Major Tom
Truck will still make it into the garage, but just.  Garage is 23 feet to the step up and 82.5 inches from floor to bottom edge of the weather strip. The light bar deflects the weather strip ion the way in an out.
Headache Rack and 52” light bar are from Magnum.
Just confirming that this is a green with blue chaser wire for B+ and black for B-?
I looked at the AUX connection and found the Gr/Bu wire on the corner of the connector.  I would assume this is the line side of the wire and if you didn't want to drill the holes, you may be able to cut and splice this wire to use as another point to connect to switch 5?
When I install my switches, I'll check power at the connector before I cut and splice into it for sure.
The green wire with blue stripe is the +12 volt connection and the black wire does go to ground.  Take a look at the link in the second post of this thread for a link to Upfitter bulletin # 157, page four and five have references to the switch connector.
  • 4 months later...
Did you get the regular height or low rack from Magnum? Any issues with the upper camera if you have one? I have one on a 1500 and love it, but not sure if it would interfere with the camera on a 3500.
This is the low rack with the light bar mounted in the lowest hole on the mounting brackets.  There is no interferance with the rear camera view, or the in-bed camera view.
look's good - Did you seal that plug ??  Why Didn't you run the wire down the back rack , come into the cab . DO ROOF LEAK
The light bak comes with a weatherproof plug with about a nine inch pigtail.  The hole in the plastic third brake light housing is sealed wit a tight fitting rubber groment with a little silicon sealer for good measure.  I live in Phoenix Arizona area.  We have only had a total of about two inches of rain in since I mounted the light bar, no leaks yet.
need to access my sw5, also installing a magnum
have you had any leak issues?
can you confirm location,  about the middle of the curve of the spoiler and 3rd brake brake light?
thanks
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
    • If we're talking futures, yes, it's speculation.   The spot price of a delivered barrel is elevated now compared to before the conflict. And that is related more to current supply/demand.
    • SPECULATION on the wars effect raised prices. AI is maximizing the profit. Refining is vertically integrated.
    • It's the Middle East conflict that raised prices, not AI. But nice distraction.
