2015 5.3 low speed/idle whine (video)
BKK
Hello,
I just got this truck a couple weeks ago and it has 26k miles. After I installed a catch can the other day I was listening intently for any vacuum leaks and driving without the radio on.
I started to notice a distinct “whine” that moves with rpms, is present when idling, and is also noticeable driving at low speeds and light throttle, and especially noticeable in drive throughs and against walls.
it almost sounds like a power steering system that has air in it. Trucks oil psi is good and there are no other issues and truck runs great.
I read about an oil pump rasp on start up (which this truck does), but nothing continuous like this one.
I am 90% sure this is a normal noise but with only 2 months left on the Powertrain warranty I want to confirm.
Here are two more videos...one driving and another at idle when you can kind of hear a “whirring” after the truck is warmed up. Hopefully you guys can hear it.
Normal.  Its definitely not power steering on 1500 trucks as those are electric assist not hydraulic.
Quote
#14-06-04-004F: Various Engine Noises During Cold Start and Warm Engine Operation - (Mar 17, 2020)
Oil Pump Cold Start Rrrrp or Rasp
The oil pump design has changed from a gerotor gear type pump to a two-stage vane type pump for fuel economy reasons. At temperatures at or below 0°C (32°F), or when the engine has been sitting for a few hours, it is possible to have air enter the pump through normal oil drain back. Upon startup, the owner may hear a short “Rrrrp” or “Rasp” coming from the front of the engine. It is most often heard during a remote start.
There is nothing wrong with the oil pump or oil system. No repairs should be attempted for this condition.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
