L86 engine upgrades
Any pros/cons on a cam swap for l86? things to get checked while the engine is getting worked on? Any trans/rear end issues after everything is finished? 125k miles, daily driven, occasional towing a boat/four wheelers..
I don't see any negatives to a cam swap at all unless you get something that isn't streetable. Delete the DOD/AFM while you're in there.
I had that turned off when it got tuned, still have those lifters though im waiting for one to start tapping so i have a better reason to swap out the cam i just didnt know how the trans/rear end would hold up if i did want to really test it
Downside to cam
-it’s pretty expensive, it’s like 24 hours of labor
-it shifts the powerband to the top end
-supercharger is not that far off in cost and really shines in a truck
upsides -
-lots of top end power
-little easier on the drivetrain than a supercharger
This is the same motor as the lt1 in the vette and the camaro. If I had a vette or a camaro, the decision would be more difficult as NA builds are awesome in lighter cars. But with 5500lbs unloaded, and sometimes maybe 15,000 lbs while towing, I’d personally rather have a supercharger.
If you diy, cam is probably considerably cheaper. If you pay someone to do it, likely around the same ballpark.
On 5/7/2020 at 12:52 PM, truckguy82 said:
Downside to cam
upsides -
Great info here. OP just make sure you do non-afm lifters if you do a cam.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 349 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
