Install just front shock leaving the spring
Is there a way to just change the front shock without pulling the whole spring and everything because just my shocks are bad rest is fine i was gonna order the belltech adjustable front shock.
Not on the coil spring models.  You have to pull the whole coil over assembly, disassemble it and reassemble with the new shocks.
Thanks @Mike GMC i see what you mean now. The ones on the truck are a little over a year old but the drivers side is leaking fluid and they both are squeaky so im going to see if theres a warrenty on them from o'riley.
