Any tips for wrapping bowties
I did mine a week ago and never really liked how they look up close. From a few feet they look fine but I'm a picky F'er.
I don't think they were going to last anyways around the edges, its not stuck all the way.
I used some cheap ebay stuff called Oracal too.
So I ordered some real 3M quality stuff this time.
Question is how do you get it to contour around the edge of the bowtie? Heat?
It's actually kind of fun to work with but I wish I knew it's limits.
Thanks guys [emoji40]
Sent from my Pixel 3 using Tapatalk
A blow drier works just fine for 3m. I did mine over the winter in a skull pattern. 3m works like butter when heat is applied. That said. Don't press too hard with your fingernails or credit card as it'll run through.
Apply the sticker from the middle outward. Then heat and smooth from the middle outward.
Also,
Leave a little extra overlap the edges. After forming the sticker onto the step down use a butter knife or something thin while applying heat and gently tuck into the crease. Razor away the extra
Yeah like Snow said. Use a little heat and it will go on smooth. I did mine in Realtree and it has held up like a champ for about 3 years.
Sent from my Cellular device utilizing a chat forum thingy.
I got mine from etsy. Overlapped the rear slightly. I cut the front short to show a slight gold border around it. Left it out in the sun for a few hours.
Not sure if you have done it yet, but this post just popped up with videos attached:
Removal and 3M Wrapping the Bowtie on a Z71
By aanold, 12 hours ago in 2014-2018 Silverado & Sierra Mods
No need to remove bowtie though. Little heat, good stiff squeegee, and good sharp exacto knife.
Mine with Vivvid Vinyl
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 420 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
