Open Club  ·  281 members
diesel 3.0
Anyone else typically running hair over 210 but bumping up to 220-225 fluctuations between that and 210 before settling usually at beginning of trip? No load- haven’t seen this happen when pulling my boat (4500lb load)
Yes I have this happen, it is usually when I first get on the highway and it will shoot up to that temp for about a minute then back down to 210
I had this happen once about 2-300 miles ago.  Was moving a bed and saw the temp creep up close to the 230 mark.  Then after a mile or so, it went back down to it's normal just a tick over 210.  I have been watching the gauge to see if it would do it again but so far so good.
Mine did the same thing one time after climbing a hill on the interstate. Then it went back down to slightly above 210 and hasn’t done it since.
Guys these trucks run really warm under certain conditions.  The cooling system is no a conventional system we are all used to. With the Active cooling system.  These trucks normally do run 210+ Max Ive seen is 226.  Why run it that hot you ask.  only time I have seen it that warm is to increase the oil temps to the 230-240 range.  As other's have noted the truck tends to by the gauge run cooler when towing.  Yes they do.  Lowest I've seen is 189f.  But this time to lower high engine oil temps(268F).  If you do monitor coolant/oil temps with an App or gauge assembly.  Its rather neat to watch.  image.png.a7519803e50e9a70d505c8288c418cf2.png
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
