The camera I'm talking about is the one that comes on when you have a trailer connected and a turn signal is on. I recently installed a camper top so I thought this camera view might be handy since I don't have a good rear view mirror picture. I took a test plug for the 7 wire trailer connector and hooked it up and now the truck thinks a trailer is hooked up so the camera comes on when a turn signal is activated. I think this will come in handy when changing lanes on the highway. Not breaking news but thought I'd let everyone know
Doesn’t that also disable rear park assist, cross traffic alert and lane change alert though? Every time I plug a trailer into my 19, that stuff is automatically turned off.
Following this thread as well.  I tried a digital trailer plug tester and it did not trigger my cameras to come on with the turn signal.  A great feature but not at the expense of turning off other features.  I'm interested in what others find here.
I'm very interested in this....
I don't have the safety package so not concerned about that.......does this work on every Silverado with the 7-pin trailer connector?
Anything else it might affect?
Cool....?
Edited by BigMick2020
I am sure this does disable bunch of features too, but I am wondering if there is a better way than leaving something plugged in. Maybe wire of the ground to something will make it think something is connected.
I did not have a front camera so I did a similar thing using the interior trailer input for the front camera.  Since the camera will not work without a trailer hooked up, I have a toggle switch under the dash connecting a light to the trailer harness that turns the camera on and off.  The only time I use the front camera is off road to see what is right in front of the bumper.  Leaving the switch off keeps the rear park alert system working and you can turn the camera on and off at anytime.  Only bad thing is the interior trailer camera input is inverted like the rear trailer camera. Don't have a fix for that.
Would you mind identifying which pins triggers the vehicle for trailer hookup?
#1 white is ground.  #3 brown tail light.  #5 Left turn.  #6 green Right turn.  Any one of the lights to ground using a non LED or an LED with enough load will trigger the trailer cameras.  I used a 3 pole switch and switched all 3 lights.  I found you get a couple more light error messages.  the messages do not affect anything.  Just ignore or dismiss.  When you turn the switch off, the trailer disconnected message appears.
I used a Curt connector that gives you the jack in the bed of the truck for 5th wheel hook up.  I spliced into those wires so there is no disturbing factory wiring.  The four conductor shielded wire ran with the wiring along the passenger side and came up thru the passenger side panel and over to the drivers side under the dash.  I made an angle iron bracket that I drilled to match a plastic bracket that is there and has a 3/8 hole.
I wish I would have located the 5th wheel trailer jack on the same side as the 110 volt outlet.  I positioned the jack so the swing up handle would miss it, but if a plug is in there the handle cannot be swung up without removing it.  I don't have a 5th wheel but a 7 pin to 12 volt adapter gives me a source for my electric refer or coffee pot since the 110 volt 400 watt inverter outlet is too wimpy to do much.
I have a 2020 1500 SLT without the Tech package.  I do have the bed view camera with the two trailer camera inputs.  Reading all the post, it seems the cameras work different for different trims.
I have purchased Tow Ready 20142 7-Way as you have suggested from another post, this works flawless! Do you have a picture, part number or a link to purchase the curt connector you are referring to? I also want to do a switch, but maybe using the signal switch with relay, so they work without needing to flip a switch
I have been trying several things and I finally was able to make it work. For a temp test I took an adapter plug that was 7 pin to a flat four. I then took a wire harness for a flat four and plugged it into it after I wired all four leads. The three hot leads (2 turn signals, 1 run light) with 3 bulbs. Then took the second wire from each bulb and connected all three together to the ground wire on the flat four harness. So you end up with 3 bulbs wired to 3 diff leads, and all three wired together to one ground.  This does not stop my back up censors or any other part of my safety features. ( I have the safety package on a 2023 AT4 )  After testing I took off all that and instead of wiring three bulbs through the adaptor and the flat four harness, I wired the 3 bulbs to the truck leads coming in from the back side of the truck receptacle just as the manufactures came into it to wire it in the first place. Now I have 3 bulbs tucked up into the back side of my bumper that nobody can see and nothing plugged in my receptacle of the truck. You must buy bulbs with two wires ( one to hot lead, one to grounds ) If you dont wire all three hot leads you will get faults telling you something is wrong with the ones you dont wire.
Add a normally closed relay in series with ground and controlled by a lead from backup light.
Install a normally closed contact relay in series with the ground and light leads connected together.  Connect the relay coil to the backup light switched lead.
     While driving forward ground is connected to three bypass lights.  While in reverse backup light circuit is activated thereby activating NC relay which opens ground to the three bypass lights, WALAA, disconnecting cameras and the system no longer thinks there is a trailer back there.
uxcell JD-1914 5 Pin DC 12V 40A
on Amazon
    250.3k
    Chevy Man for Life
    Chevy Man for Life
  • Who's Online   4 Members, 0 Anonymous, 593 Guests (See full list)
    • Glad it worked for you. I tried that 1st, about 2 years ago. Didn't help. I also tried doing a hard reset (disconnecting battery for minimum of 30 minutes). Worked a couple times, but after one summer of doing it over and over, that no longer worked.  I was fairly confident it was either the compressor or a failed actuator, but I just couldn't identify which one. Had to research which actuators do what and which last numbers are associated with each.
    • Took me FIFTEEN MINUTES to find this. Isn't that a problem? On the mainstream media I can INSTANTLY find 100 articles bashing President Trump ... but when it comes to TRUTH in American corporate news & search engines, it's carefully filtered to support ONE SIDE. A Republic cannot survive like this! Incredible! Even all the AI searchers out there failed as well! ChatGPT said it needed more details on the video that I provided a DIRECT LINK to! I thought AI was the be-all, end-all?? I had to dig it up myself. This should be FRONT PAGE NEWS!!! 🤬   Here's the statement directly from our President:     Glenn Beck's reporting on the operation:   https://glennbeck.com/watch/videos/trump-just-revealed-a-massive-military-secret-that-lowered-gas-prices   In case that link doesn't work, here's the YouTube link:     And another 15 minutes to find this clip out of Glenn Beck's video - the first few seconds is all the corporate media will allow the public to see, since the low IQ people will think Trump said " I love inflation ", and that was the end of it. Taken WAY out of context! Here's that part, plus the 2nd part about the oil smuggling operation:
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
