The camera I'm talking about is the one that comes on when you have a trailer connected and a turn signal is on. I recently installed a camper top so I thought this camera view might be handy since I don't have a good rear view mirror picture. I took a test plug for the 7 wire trailer connector and hooked it up and now the truck thinks a trailer is hooked up so the camera comes on when a turn signal is activated. I think this will come in handy when changing lanes on the highway. Not breaking news but thought I'd let everyone know
Doesn’t that also disable rear park assist, cross traffic alert and lane change alert though? Every time I plug a trailer into my 19, that stuff is automatically turned off.
Following this thread as well.  I tried a digital trailer plug tester and it did not trigger my cameras to come on with the turn signal.  A great feature but not at the expense of turning off other features.  I'm interested in what others find here.
I'm very interested in this....
I don't have the safety package so not concerned about that.......does this work on every Silverado with the 7-pin trailer connector?
Anything else it might affect?
Cool....?
Edited by BigMick2020
I am sure this does disable bunch of features too, but I am wondering if there is a better way than leaving something plugged in. Maybe wire of the ground to something will make it think something is connected.
I did not have a front camera so I did a similar thing using the interior trailer input for the front camera.  Since the camera will not work without a trailer hooked up, I have a toggle switch under the dash connecting a light to the trailer harness that turns the camera on and off.  The only time I use the front camera is off road to see what is right in front of the bumper.  Leaving the switch off keeps the rear park alert system working and you can turn the camera on and off at anytime.  Only bad thing is the interior trailer camera input is inverted like the rear trailer camera. Don't have a fix for that.
Would you mind identifying which pins triggers the vehicle for trailer hookup?
#1 white is ground.  #3 brown tail light.  #5 Left turn.  #6 green Right turn.  Any one of the lights to ground using a non LED or an LED with enough load will trigger the trailer cameras.  I used a 3 pole switch and switched all 3 lights.  I found you get a couple more light error messages.  the messages do not affect anything.  Just ignore or dismiss.  When you turn the switch off, the trailer disconnected message appears.
I used a Curt connector that gives you the jack in the bed of the truck for 5th wheel hook up.  I spliced into those wires so there is no disturbing factory wiring.  The four conductor shielded wire ran with the wiring along the passenger side and came up thru the passenger side panel and over to the drivers side under the dash.  I made an angle iron bracket that I drilled to match a plastic bracket that is there and has a 3/8 hole.
I wish I would have located the 5th wheel trailer jack on the same side as the 110 volt outlet.  I positioned the jack so the swing up handle would miss it, but if a plug is in there the handle cannot be swung up without removing it.  I don't have a 5th wheel but a 7 pin to 12 volt adapter gives me a source for my electric refer or coffee pot since the 110 volt 400 watt inverter outlet is too wimpy to do much.
I have a 2020 1500 SLT without the Tech package.  I do have the bed view camera with the two trailer camera inputs.  Reading all the post, it seems the cameras work different for different trims.
  • Thanks 1
  • 1 year later...
I have purchased Tow Ready 20142 7-Way as you have suggested from another post, this works flawless! Do you have a picture, part number or a link to purchase the curt connector you are referring to? I also want to do a switch, but maybe using the signal switch with relay, so they work without needing to flip a switch
  • 2 months later...
  • 1 year later...
I have been trying several things and I finally was able to make it work. For a temp test I took an adapter plug that was 7 pin to a flat four. I then took a wire harness for a flat four and plugged it into it after I wired all four leads. The three hot leads (2 turn signals, 1 run light) with 3 bulbs. Then took the second wire from each bulb and connected all three together to the ground wire on the flat four harness. So you end up with 3 bulbs wired to 3 diff leads, and all three wired together to one ground.  This does not stop my back up censors or any other part of my safety features. ( I have the safety package on a 2023 AT4 )  After testing I took off all that and instead of wiring three bulbs through the adaptor and the flat four harness, I wired the 3 bulbs to the truck leads coming in from the back side of the truck receptacle just as the manufactures came into it to wire it in the first place. Now I have 3 bulbs tucked up into the back side of my bumper that nobody can see and nothing plugged in my receptacle of the truck. You must buy bulbs with two wires ( one to hot lead, one to grounds ) If you dont wire all three hot leads you will get faults telling you something is wrong with the ones you dont wire.
  • 1 month later...
Add a normally closed relay in series with ground and controlled by a lead from backup light.
Install a normally closed contact relay in series with the ground and light leads connected together.  Connect the relay coil to the backup light switched lead.
     While driving forward ground is connected to three bypass lights.  While in reverse backup light circuit is activated thereby activating NC relay which opens ground to the three bypass lights, WALAA, disconnecting cameras and the system no longer thinks there is a trailer back there.
uxcell JD-1914 5 Pin DC 12V 40A
on Amazon
    TopBo
    TopBo
  • Who's Online   1 Member, 0 Anonymous, 1,086 Guests (See full list)
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
