Quick comment, I took a drive earlier and it moved back up to 1/2 full.  The description above from @redwngr is likely what is happening.  Thanks again!
Have gone 800 some odd miles, added 2.5 gallons of def and the level shows to be very close to what it was when I drove the truck off the lot.  So probably around 320 miles per gallon.
Slightly different because I actually am on my second part being replaced in 10k miles. At 2k I noticed a burning smell and smoke under my hood. Took it in. They said it was a ceramic coating burning off. I accepted this. 5k miles later I take my trailer on a 3k mile trip. At the end of the trip engine light comes on. Its the PPF. Packed full of carbon.  Dealership said it was the smell and smoke from the issues at 2k. Had it replaced.  Blue def usage is tops at 300 miles a gallon. Its now in the shop because the blue def float sensor is bad and was false reading and putting the truck into limp mode. GM is repairing that without a code. From what I read people have been getting 1k miles a gallon out of this model. Mine is just one exhaust issue after another.
Kind of wondering if this is a common issue and this is something I am kind of watching for on mine right now.  My level showed it was at like 3 bars a couple weeks ago, according to the supplemental manual it should have been able to take 3.5 gallons of def.  I added less than 1.5 gallons and it was full at the tank, overfilled.  The level then showed one bar less than full.  Drove for about a hundred miles with it at that level and then the level went to full, all bars lit up green.  It has been showing full for the past 200+ miles since.  I question the accuracy of this.
When the sensor went it would go all over the place. Full, half full 160 miles down to none at all while in park. Took 2 trips to the dealership to get them to realize that it was reading full and there was one gallon of def in the tank.
7500 miles so far on my 2020, picked it up with a full def tank and I’ve put over ten gallons in it myself. Just made a 2k miles trip pulling a 24’ Livestock trailer Not even half loaded And went through 5 gallons easily.
My gauge stayed pegged to the full side for nearly 1000 miles.  Finally went down one bar, then after about another 500 miles it went down another bar.  Will refill it when I get to about 3 bars and see how much it takes to fill it up.  So not really sure how it is doing now, but seems to be a little better than my early estimations.
Anyone interested in finding out what their truck is really getting for def mileage, find a nearby bulk def location.  Likely in a truck stop. Likely in the truck lanes.
This 3.0L wasn't full when I got it so today I decided to fill it so at next fill I'll be able to calculate mpg.
Anyway, with the new def fill beside the fuel fill it is super easy to use the bulk pumps.
The do have auto shut off.  I was in noisy fuel lanes so there was no way it would be possible to hear change in sound as fluid level starts up fill tube.
DEF pump nozzle shut-off worked perfect.  No splash back.
Just like checking fuel mileage, the only way to check def mileage is to fill tank, record odometer, drive, refill tank.
Miles driven divided by gallons to refill.....
If the tank isn't filled at both the start or end of exercise, then the mpg is just a wild ass guess.
I have a 2020 Duramax 3500 single axle 4x4 pickup and I have used over 10 gallons of DEF fluid since new.  I am currently at 4700 miles with 1/2 of the DEF tank remaining according to the DEF gauge.  This seems excessive to me since my brother has the same truck in 2018 that he has never added DEF fluid to in 14k miles.  He is at the 30% mark in his pickup but hes waiting to get that level really low before adding more since it has been in the truck so long.
My problem seems to have been fixed? since I had the def tank replaced.  They did it because I kept complaining about it and after a lot of screaming and several trips to the dealer after the gauges kept freaking out they said it was per customer request. Night and day difference all around.  Def usage is where it is supposed to be and gas mileage has improved.  Thinking they may have thrown in a update also but nothing was said to me.
I also had a 2016 DRW Silverado and I just got a 2020.  I’m in Canada so we go by KM.  I’ve driven about 1700km and burned half a tank of DEF.  it seems very excessive to me.  I called the dealer and they are looking into it .
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 636 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
