On 2/23/2024 at 12:41 PM, Stacy Coggins said:
Has GMC found a fix for this issue. My 2019 Sierra Denali is doing the same thing. It is a royal pain in the back side.
This is certainly not what we like to hear, Stacy Coggins.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2019 GMC Sierra. To do so, please send an email to [email protected] with ATTN: Stacy Coggins/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
I have had this problem for over a year. Finally after getting frustrated and left stranded because battery went dead over night and vehicle had to be jumped to get started. i had the bypass wire put in cause GM dealer said that it is not a factory problem and I would have to pay to have it fixed. Vehicle is a 2019 with only 22,000 miles. The bypass is working great so why spend the money. Why are the complaints on here so many if the problem is not a factory defected part.
My wife's Blazer did this and they replaced the whole shifter assembly. Two weeks later we had to take it back and found the battery was in need of replacement because it was affecting the backup camera which was having issues the first trip to the dealer. Check your battery if it is older than 3 years and make sure it isn't the culprit.
  I had same prob with 2022 silverado 6.6 diesel. Shift to park message, took it into dealer thinking just 2 years old now, Has got to be covered by warrantee... $1177.67 later Its got 3 year/36000 mi warrantee. 53920 miles on my truck!! So I guess 5 year\50000 mi drivetrain warrantee is up too already. Cant win
My 2019 GMC Sierra started with this issue several months ago.  Problem was very intermittent.  Some days it would alarm for up to 30 seconds.  Other days never had an issue.
After lots of research and seeing many comments I solved the matter today.
under the steering column is a small switch which should be closed when the shifter moves to mark.  This switch seems to be made of the cheapest parts available.
Remove the 7mm bolt under the column.
Turn steering wheel to the right and you will see a 2nd 7mm screw.  Then back left and remove 3rd and final bolt.
at this point you can pull out the bottom half of the steering column off exposing the switch.
You will see 2 black wires connected.   I soldered a small jumper wire across the 2 black wires.
put everything back together. 45 Mins including a test drive.
Problem completely resolved.
if you wish to order a replacement part another posting listed it as. GM 84800776.  I have not verified the part as accurate.
Good luck with your repair.
I can't find the actual switch....somebody posted a part number but thats for the whole assembly......I just need the switch....I did what the YouTube video said and it helped a little bit but it still does it sometimes!! I wanna replace the whole switch but I can't find it anywhere somebody please help!!
They don't sell the switch.  Its part of the shift control.
Hello, new to the post.  Had same issue with 2019 Sierra Denali, 70,009 miles, took it to dealer, they had it 3 days, said there was a service bulletin about corrosion on transmission ECM.  Cleaned wires and put dielectric grease on and they said it was fixed.  Drove it home and as soon as I turned off truck, the shift to park message came back.  I immediately pulled the column apart, removed the switch, wire nutted the wires together and it went away.  Will order a new switch tomorrow!  Thanks for all your help.
2019 Sierra Denali, same issue.  Dealer had it 3 days, charged me $170 and it didn’t fix the problem, they said service bulletin about corrosion on transmission module wires.  As soon as I got home and turned off truck, message happened again.  Took apart column, removed switch, wire nutted wires together, problem went away.  Will order new switch tomorrow, thanks everyone!
@GMCustomerService is there a timely solution to the shift to park error message?
I brought my truck (2022 GMC Sierria 1500 Denali) to the dealership to remedy the problem, I was told replacement parts are in short supply and would take months before they are in stock.  Please advise a better solution.
Looking forward to your response.
Had the same problem on my 2019 GMC Elevation.   I cut the wires to the switch under the steering column and spliced them back together basically eliminating the switch all together.   Haven't had the message return since I did this.  GM won't acknowledge the problem.   It should be a recall.
Cut the wires to the switch and splice them back together.
On 8/2/2024 at 3:24 PM, RonP68 said:
Anyone have instructions on the best way to jump the switch?  Never done this before.
Follow the instructions above on how to remove the steering column.   Then cut the 2 wires going to the switch and splice them back together.   Essentially you've eliminated the switch.20240128_145716.thumb.jpg.31cae5e5515e67a252ca39f17ee9e14b.jpg20240128_145647.thumb.jpg.a61bfdd89f481ad22e9cab575a9e7389.jpg
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 372 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
