Has anyone done this? If so what is your set up? Seems like most have the dual that are upgrading, haven’t found much on upgrading the single. 2020 LTZ 5.3
I don't have an answer.  I have the same question.  I've got a 2020 GMC SLE with the dual tips.  Would like to have an actual dual exhaust, not just tips.
I did it about 1 month ago. I ordered a corsa 21028 cat back kit, which at the time I purchased they had a $125 rebate so it was free shipping and a rebate. The dual corsa system matches up with the frame but I had to weld up my own exhaust hangers for the rear exits. The truck is also missing the driver's side heat shield for the spare tire but I opted to use titanium exhaust wrap off amazon which is far cheaper than the stock heat shield. The rear bumper actually has the cutouts for the chrome tips on true dual exhaust trucks but you would have to change out the bumper cover I believe and buy tips as well. The corsa system exits as a slight down angle so I felt that enough to clear the bumper and exit nicely. No need for tips, forcing my wallet to diet was taking its toll....you'll need 1/2 exhaust hangers which I got off ebay and the rubber exhaust hanger itself also off ebay.
Overall it turned out great, sounds great, with the GM cold air intake and thier recalibration, I swear the truck is a whole different animal now.
I just had the GM CAI installed Saturday, damn dealer didn't do the flash so I have to take it back. I ordered a  dual rear exit Borla exhaust that the GM accessoies site said would work with my truck but the dealer said it didn't work. Looking at the Stainless works Legend double side exit but don't see many reviews on their exhaust so still up in the air between that Corsa 21030 or the Borla single touring.
Did the dealer say why it wouldn't work? Length of bed? Crew cab or double cab? I have a double cab with a standard bed. They may also be saying it doesn't work because your rear bumper isn't configured for it. I took the chance with the dual rear knowing I was going to fabricate my own hangers so I could drop the exhaust lower than my bumper. If you know someone who can help you do that or if you're in Vegas I can help you out. Go with dual rear, you won't regret it.
Do you have any pictures from the rear of the truck. I was thinking of doing the same and I'm curious what it looks like from the rear. I do worry about the heat from the exhaust traveling upwards into the bumper assembly and possibly damaging the parking sensors or plastic trim.
Sorry I think my pictures are too big to upload. I hit the limit. PM me and I can send more. My truck doesn't have the parking sensors and I don't have any wiring above the exhaust. I'm not sure I'd it made a difference or not but I installed the factory GM 2" lift kit also.
Thank you. That's exactly what I was looking for. I like the look. I really want to swap out the bumper shell for the one with the cutouts and then do the exhaust. I just don't want to part with the money.
3 minutes ago, 2liter said:
Stealership wanted $800 for the bumper
I wouldnt have thought any less.... and that's probably not even painted as well.
Check out gmpartsdirect or other gm part places.
The part number for an Elevation, probably all models with dual exhaust is 84574365 Rear Bumper Cover Primed $443.
That's a start, but then you'll have to buy the tips which are roughly $90 a piece, then have to have the exhaust welded into the tips which will require a stainless welder, and I'm not even sure those tips are stainless too. That's a lot of bending and sheetmetal work which I didn't want to hassle with even though i could do it. The cost of the cover and painting it wasn't worth the hassle to me. I used the money to pick up some lights for the front and lift kit, etc.... there's another thread here i just saw of a member posting his corsa rear system with a video and sound. Mine sounds exactly like that. No regrets at all. Next I'm cutting out that flattened pipe under the transmission and welding in a straight one. I've got the time that's for sure.
How is the sound in the cab. Have you towed anything with it on?
Sounds great, in fact I want it even more rough. Wish it was more like an old school 350 with a cam and 4 barrel Holley. Never towed anything yet. Was going to this week but only a 22ft flat bed trailer to pick up 20' sticks of steel. This is my third corsa system all in trucks. Can't go wrong if you ask me. I really don't know what the dreaded drone sound is that members speak of. I changed my exhaust after 2 weeks of having the truck so maybe I missed it during that time. I think headers and a y-pipe will come later.
  • 9 months later...
I have seen this question couple of times, about the towing with the upgrade dual exhaust. Could this be a problem? asking because I want to do this upgrade, an Im towing almost all the time
Since swapping the bumper cover to the dual outlet bumper cover is so cost prohibitive, has anyone just reversed the exit offsets on the stock exhaust pipes and had the exhaust exit under the standard bumper? Seems like it would line up just right.
If you removed the offsets you could come straight out under the bumper and add tips, no?
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
