Diesel Fuel Additive
From  what I've been told?
No.   Don't use it.
The 2-20% bio content is supposed to have enough lubricity and the additives won't do anything but speed up how fast the DPF plugs up.
Some do, some don't. Some that do/did claim they had dpf trouble -- others say there was/is no problem.
I've never used additive in any of mine.
I also never buy fuel from discounters, which imo, are less likely to have a good additive package in their fuel.
GM does offer one if you are concerned about your fuel source(s).
No doubt some of the aftermarket ones are just as good or better than what GM/Delco offers.
Lubricity study done 10 or so years ago found that some additives reduced rather than improved the lubricity.
One of the best at increasing lubricity was biofuel, as samuse posted.  Depending on where you are, biofuel may not be appropriate for winter months.
  • 3 weeks later...
The owners manual recommends using "TopTier Fuel" from stations that are supposedly putting a specific type additive in the fuel/gasoline that meets these new standards for cleaner burning fuel that reduces carbon and keeps your fuel system cleaner. This just rolled out a few years ago and just know seeing more stations adopting this new standard. You usually see the logo on the pump or advertised at the station.
https://toptiergas.com/consumers/
You won't find top tier diesel in very many places right now.  That being said, I strongly recommend running an additive.   OptiLube seems to be the one of choice thus far from the people over at duramax forum.  I've been running it and no issues on my 08 and was running Diesel Kleen prior that, again no issues.  Injectors are super super expensive and the additives do help extend injector life.  Just what is suggested not more.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
