Everyone that's done this mod simply does it and shows off their puddle lamps when completed. But they never tell you how to do it.
This won't be much, but after an extensive search on this subject, I haven't seen any real pictures of the original puddle lamps. Not much to it, but apparently the passenger side puddle lamp was installed a bit wonky and the clip was extended out too far where I couldn't even find it with the mini-screwdriver I used to try and get it out. I figured I did something to it so I went with a scribe tool thinking I needed something skinnier.  Nah. It was on the assembly line. Anyway, if you follow the included instruction sheet for the puddle lamps, about the only good thing it tells you is the color code for which side you need to put your lamps on. In GMC case, it says blue decal goes on driver side, green decal goes on passenger side.
It actually is pretty simple. But it's kind of a PITA to reach up under the mirror and fish for the indentation on the end of the clip. You would think it would be right there, but it's not. So holding a flashlight and fishing around with the scribe tool...not bad, but I'm getting too old for this sh*t.
Only difference I found was the passenger side OEM lamp and the new lamp have the prongs backwards. One prong for the plug is vertical, the other is horizontal. No biggie, just rotate the plug 180 degrees and plug it in. Checked for proper operation first by covering the light sensor in the middle of the dash to make the truck think it was dark out, then clicked the unlock buttons. Nice little GMC logos lit up the palm of my hands. Then just snapped them in place. Done.
2061440654_GMCPuddleLamp1.thumb.JPG.4e98f3459d78d1ee96b28a7602d758d7.JPG498298050_GMCPuddleLamp2.thumb.JPG.a65ba488aca5bf9cb7c3c2b109da2ac7.JPG19939121_GMCPuddleLamp3.JPG.22f9fedf78a592f889f2bbc6fcd59f22.JPG2095291285_GMCPuddleLamp4.thumb.JPG.662e5c6f662daf0b2c7c55e9afdb98fb.JPG1508209416_GMCPuddleLamp5.thumb.JPG.9bde854d25be4a9658b9a2a8399d79e3.JPG
I'm curious what these lights would be used for as I've never had them on prior vehicles.  I have them on my AT4 but in over a year I've never used them.  What am I missing?  In what scenario are they useful?  FWIW, I'm genuinely interested in their purpose and am not trolling.
They basically are supposed to light up the ground or side steps at night when you unlock the truck. To be honest I didn't even know I had them on mine until I looked to see if I could replace them with the BowTie ones because they were so dim. Now with just the bowtie its a novilty and does't really serve any good purpose. But the sure do look cool! LOL
Thanks.  I find it interesting that manually cycling these lights with the switch turns on the right side light only with the first push of the switch, the second push turns off the right side and turns on the left while the third push then turns on both left and right.  A final push of the switch turns both off.  I thought there was some "hidden/cryptic" usage for these lights the way they provide for the cycling I listed above.  I personally find them about as useful as ****** on a boar hog...
I think you are think of the work lights on the front of the mirror.
Sent from my SM-G973U using Tapatalk
Yes sir, that's what I'm talking about.  Aren't these the lights this thread is addressing?  If the ones I'm talking about are "called" work lights I'm not certain what kind of work I'd be doing that light projected straight down to the ground below the mirrors would prove beneficial.  I'd appreciate anyone that could enlighten me on how these "work" lights would prove useful.  I'm missing something...
No. The "task lights" are the front of the mirror. The ones discussed here are the puddle lamps. They're located on the bottom of the door mirrors (see enclosed picture). A single LED light on each from the factory if your truck has them. Mine's maxed out with all the goodies so it has all those little items. To note, the packaging says they only work on trucks equipped with factory puddle lamps. But if you can swap the housing piece to one with puddle lamps, and wire it up, you could probably make it work on any truck that didn't come with them from the factory.
I sold some parts from my old 2010 truck parts stash, so I figured, hey, why not get these nearly useless little trinkets for shining a "GMC" logo for under the mirrors on the ground with some of that money. They only really can be seen at night when you remotely unlock the doors. The factory lamps are virtually invisible and don't do much anyway. The logo projector puddle lamps are like the lighted GMC grille logo. Doesn't do much but a nice little upgrade to promote the brand.
Edited by 2020SierraDenali
Ahhh, thanks.  I didn't know "puddle lamps" existed.  I appreciate you taking the time to educate me.  FWIW, I can't view your picture.  I shows a file named "spacer.png" but does nothing when I click on it.  I wish it did as I'm curious to see how they project the logo.
Hmm. The picture shows the GM promotional picture of what the puddle light projection should look like. It's all kind of useless. It's one of those deals where if you have $100 burning a hole in your pocket and want to do a virtually useless upgrade...I went back and edited my post and uploaded the saved picture of the same thing. Maybe it will work now.
Quote
I am guessing you have the tow mirrors with the work lights.
I have the tow mirrors and have not found  puddle lamps.
The mirrors option is listed as DQS which has the  puddle lamps listed but darn if I see anything under the mirror.
LTZ with tech camera package with surround views.
Maybe you loose the puddle lamp with camera package?
  • 3 years later...
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
