Hey guys, was under my K3500 just looking stuff over. Found a grease zerk on my front drive shaft (from transfer case). I’ve never see one on a shaft like that. I cleaned it up, and greased it. And put a cap on it like i do with all zerks. Took quite a bit, 9-10 pumps.
Is that a common zerk spot for 1 tons?
maybe post a pic of the zerk location.  If it's on the u-joint, that wouldn't be unusual, or possibly if it's near the sliding yoke, you might be pumping gear into the sliding area...
My 84 K-20 HD had one too, so it's not exclusive to 1 tons. My guess is that it's more common on front straight axles rather than IFS 4WD because of the suspension and front drive-line travel.
4wd trucks have a zerk for the slip joint on the front driveshaft, regardless of brand or if it's a 1/2t up to whatever.  I'm sure there is an exception or two somewhere in the world.  And yes, it's a great idea to keep it greased.......
