Hello Everyone,
I am thinking of lowering my truck a little bit at 30K(miles) im at 23K right now and would like to know if there are any issues with doing this. I really only want to lower the front by an inch and the rear by 2". I know that pinion angle issues have arise so i have bought a pinion angle gauge.
I believe i will be installing;
2x 25019   (beltech)
2x 6416     (beltech)
and probably buy some shim/angle kits to verify pinion angle before and after.
Installation instructions for strut;
https://www.belltech.com/extras/docs/BBGC/28019-888.pdf
Edited by BlancoSilverado
10 hours ago, BlancoSilverado said:
Hello Everyone,
2x 25019   (beltech)
2x 6416     (beltech)
You should be fine with that minimal drop, what are your concerns?
im asking to verify that there are little to no concerns
  • 1 month later...
On 7/2/2020 at 10:11 AM, BlancoSilverado said:
Hello Everyone,
2x 25019   (beltech)
2x 6416     (beltech)
Any updates?
I'm thinking of installing this same beltech set-up you mention above, thanks...Rich
1 minute ago, Puttnutt24 said:
Any updates?
Im just rolling over 25k right now. It will be a could more months before i do the actual lowering.
I did put bilstein rear shocks on. I know i shouldn't lower but i might just do 1" in the rear instead. because i cant really do anything. I might run to a pick and pull and pull and adapt a sway bar for the rear of my truck.
