Hey all,
I have a 2019 Denali that I have been trying to chase down a rumble in the cab when I’m decelerating from about 30-20 mph. I think it is pinion angle related or tq converter. My truck has shims under the rear leaf pack to adjust the angle from the factory.
There are a couple of threads about the rumble but nobody has seemed to be able to solve it. One guy did with flipping the shims but his truck was lifted so trying to figure out the protocol on a stock truck.
I have had a few loaner trucks and they had the very slightest rumble not anywhere near as bad as mine and the 2020’s don’t have the shims.
My question is, do you think GM arbitrarily added shims to 2019 trucks or did they truly measure driveline angles and put the shims on the trucks that needed it.
That being said, why would the 2020’s not have shims? What might have changed that they didnt need them?
I’m just trying to do some research before I pull the shims on my truck out which seems to be a bit involved.
Thanks in advance for any insight!
Try loosining the tie bolt and spinning the shim 180°.
I know spinning it has worked for you guys with lowering/level kits in the rear but my truck is completely stock.
That being said, it might be worth trying to see if it makes it better or worse instead of taking it completely out. Only problem is that swings the pinion angle like 4 degrees instead of just two by removing it.
I've ridden a '20 that had a slight vibration on decel. Try spinning shim; it's worth a try.  If it doesn't work you may have something else causing it.
Agreed, I’ll give it a shot. It’s either that or the torque converter, hoping it’s as simple as the pinion angle.
I have a 19' and lifted it 1.5in in the rear and 1in in the front since my High Country came almost level from factory. After I didn't like the rake so ordered a 1in block instead of the 1.5in and WOW major vibration like you have, decel from 40 or so down. It was so bad I thought I had messed up the truck. Got it back and changed out to the 1.5in and it was gone well almost gone. Now that I know what it feels like I can still feel it when I decel, it's about 95% better but I can still feel it.
So it seems like these things are VERY sensitive to driveline angle, I'm going to run up the street to look at an AT4 and see if the shim is in there and which way for mine. As for yours have you brought it back to the dealer?
Yeah, I think these trucks are super sensitve to driveline angle. I took mine to the dealer back in January and they had it for a week and couldn't figure it out. That being said, they didn't even mess with the shims or driveline angle, they are not very competent to say the least. All they did was tests on the transmission and reported back to GM and GM deemed it "operating as normal". They said they drove a few trucks on their lot and a few did it worse than mine and a few were better. I wouldn't want to feel the trucks that were worse than mine because mine is VERY noticeable.
I think they put shims in all of the 2019's because they didn't know what they were doing. The fact my rear diff is 4 degrees off from the factory is pretty alarming. I had the rear window leak on my truck and had two 2020 loaners, same config as my truck, 8 speed trans and neither one of them had the shims and they didn't have the rumble on decel. I think that's the culprit on mine, just need to get some time to remove or spin the shims. By my calculations, removing it is better than spinning it to correct my angles.
42 minutes ago, CMillSilverado said:
Do you even have a 19+ GM??
So you think physics changed for 2019 and beyond?
Interesting idea.
Wonder if gravity will work tomorrow.
Interesting idea.
15' and 19' trucks are not the same, stay with what you know.
Same information will apply.
News Flash
The drive shaft physics is.
:wtf:
Psssst. We are not doing this, read me?
:thumbs:
There is something differnet, I had the same lift on my 17' and set up the driveline angle and had zero vibration, did the same to the 19' and there is vibration.
Did you check your angles?
    DM22
    DM22
  • Who's Online   0 Members, 0 Anonymous, 1,821 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
