I have a 2020 Silverado LT with the 8" screen, without Bose.
I'm sort of confused on what all is needed to install a subwoofer and I need some advice on what to buy as well. I want to use the subwoofer as a supplement to my terrible factory speakers. I had good luck doing this with a previous vehicle. I took the bass burden off the door speakers and I had the sub handle all the bass frequencies.
So far I'm looking at this enclosure with the included amp. 200 watts is plenty of amp for my needs.
http://subthump.com/Chevrolet-GMC-Custom-Subwoofer-Boxes/Silverado-And-Sierra-Crew-Cab-Custom-Subwoofer-Enclosures-by-Subthump/2019Up-Crew-Cab/New-2019-New-Body-GM-Crew-Cab-Dual-1012-Downfire-With-Amp-Space-clone.html
And then I'm looking at this harness, but I don't know what add-ons to select. I want the minimum configuration to get around the bass roll-off from the factory.
https://lljcustoms.com/store/ols/products/2014-2018-gm-t-harness-for-8-screens-without-bose-1418gm8
I'm also wondering if the bass knob that's included with the subthump kit will be compatible with the LLJ customs harness, or if I have to buy a separate bass knob that's made for that harness.
And finally, the question of which subwoofer to choose. Like I said earlier, I would like to supplement my factory speakers with this sub.  I think the mounting depth of the box is 7". Should I be looking for something that has a wider frequency range? I would like a very tight and punchy speaker for the kick drum, but something that can fill in the other frequencies as well. I listen to almost every kind of music. EDM, Metal, Classic Rock, Country, and once in a rare while even Hip Hop. This enclosure allows for round or square 10 inch woofers.
Any help is appreciated. Thank you
Edited by Var Nazari
typo
Get the harness from John people have had problems with llj customs. John’s email is  [email protected]
he will answer all your questions and give you several options on harness
I just emailed him. Thanks
No problem he made my harness for my sub install and I got the lc2i from him. On the sub thread a lot of people where having problems with lljcustoms. That’s where I got John’s email from.
He just emailed me back saying he's closed until mid September. So I guess my choices are limited now
1 hour ago, Paul 2020RST said:
Does anyone have the color wires being used to go to the LOC?  2020 RST w/ Bose
Which speaker signal are you trying to hook up to the LOC, Bose subwoofer or door speakers?
I’m guessing the sub, even though the doors seem to play more bass.
I have a 2020 w/ Bose and was able to locate and access the sub speaker wire beneath the center console without removing the console or any seats. I haven’t seen anyone post on this method yet so here it is.
Remove the plastic side panel from the center console on the passenger side. Think it was held on by several panel clips.
Slide the passenger seat all the way back to expose a carpet seam at the bottom of the console. Pull the carpet flap and peer under the console towards the rear of the vehicle with a flashlight. You should see a thin harness wrapped in black tape anchored to the floor with zip ties.  There are only two wires in the tape.
You should be able to get a hand or panel tool in there to wiggle the anchors loose from a threaded stud or bolt.
There wasn’t much slack in the harness but try to pull as much out as you can. Carefully snip the black fabric tape exposing a green and a blue wire. I can’t remember which wire was positive or negative.  You will probably have to research wiring diagrams or someone may recall.
I scored and slid the wire insulation to the side exposing the copper wire and then soldered speaker wire to it. Sealed it and taped it back up and put it all back together.
Ran the speaker wire under the passenger seat rails inside a seam in the carpet to the passenger door sill. Then ran it inside the factory wiring track along the passenger side under the door sills to the rear seat where my LOC is located.
This may be difficult to follow so here are a couple images. I hope this helps out the installers out there.
I did not have to bypass the ANC for my minimal setup with just a small single 10” sub supplementing the existing oem sub.  I don’t believe ANC is canceling any of my audio output and likely determines my sub’s output as music instead of noise.
I did not need a remote turn on signal for my amp because it already has built-in auto power on sensing the audio signal coming from the Bose sub speaker I tapped into.
Ok great, thanks. I just want a small sub as well. Maybe I'll be fine without cutting the anc. Worth a shot. Thanks.
Sent from my SM-G965W using Tapatalk
I don’t know enough about how the ANC works with GM but I suspect that it sends an audio signal out of the speakers including the sub to cancel out road noise. So far while driving around, I haven’t heard the sub doing anything weird or muting itself out. I’m certain you will be fine with a small setup not meant to blare out the cars next to you in traffic.
Edited by Rook126
So I found those 2 wires and tapped into them. Both putting out approclx 6.1v. I have a PAC LOC hooked up so only 1 speaker is supposed to get a signal. However I hook everything up and nothing comes out. MY PAC is dual channel but I imagine if I hook 1 side up I should get a signal. I only have the 1 sub on the amp. Thoughts?
Some thoughts.
Check the PAC LOC wiring. I had an older 2ch LOC a while back that required a different combination of input wires to be used if running in mono. Some LOCs require a dedicated ground connection.
Are you using a stereo or mono amp? If stereo, check to make sure you are on the same channel (left input/left output) etc.
Double check any other settings on your amp, switches and gains.
If you have a dual voice coil sub, be sure you are connected to terminals on the same VC.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,136 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
