Windshield Replacement - Any issues to look out for?
I'm getting my windshield replaced due to a crack, glass that is being used is a genuine GM replacement windshield.  It'll be replaced at the GMC dealer by their regular subcontractor that does a lot of windshields for them.
Other than the brand of glass used, has anyone had theirs replaced and anything to look out for / check when done or problems you ran into?    Any noticeable difference in wind noise after?
My truck does have the big windshield mounted sensor up behind the rear view mirror which probably makes it a bit more complex as well.
TIA
Inspect for adhesive after install. Had mine done in my driveway, Satellite, came out perfect as far as i can tell.
Mine cracked and the windshield place only needed to know if it had the sensor or not which I had as well. I believe it was a little more cost, (roughly $230 non gm dealer). No issues after the fact, other then a catching a rock a week later [emoji20]. Luckily it was the bottom right corner so it doesn't bug me. But the new one is holding up to that rock chip a year later.
Thanks Mike and GH - did either of you hear any difference in wind noise after the replacement?  Know it isn't luxury car quiet from the jump, but hoping not to add more noise to the equation.  I've only got 20K miles on my truck so the glass (other than the crack the dealer's mechanic put in it while changing my wiper blades) is in pretty good condition.
I took pictures of the window surround inside and out, OEM glass label, placement of my EZPass Transponder and dashcam mount with a measuring tape (also printed this out for the installer) while I wait for the glass to arrive to I can compare before and after.
    Smitty462
    Smitty462
  • Who's Online   5 Members, 0 Anonymous, 703 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
