I have a 2019 Silverado 1500 LTZ. I am wanting to add extra lighting on the rear of the truck so that when I backup a trailer or hay rack in the dark I can see better. I have upgraded the reverse bulbs to led. I was hoping to add pod lights to the rear bumper or around the hitch and hard wire or tap them into the reverse lights. I would prefer to not have an extra switch to hit to turn them on. What has everyone done or does anyone know of a harness I can tap into the reverse lights?
TIA
TIA
Welcome - on my last truck had 2 - 1 x 6 pods mounted to the hitch cross bar , drill a hole and mounted on each side , ran two wires one for left & one for right and tap into Rev light wire . they came on when truck was in rev. . NO Problem.   OR you could mount two flush mount to the bumper .
This is the setup I’ll be running, I suggest tapping into the cargo lamps.  That will allow you to use them in reverse and park.  The mount is from Amazon
That’s the route I was hoping to go. If you’re tapping into the cargo lights so they work when in reverse and also in park with the cargo light switch, would you be able to post pics of how and where you tapped into them?
TIA
TIA
I did it on my 17', the wires were right behind the rear bumper.  I'll be installing everything in a few weeks, I'll let you know.
Edited by pewterliftedz
I ended up purchasing the BLADE QUICK CONNECT - 2019+ SILVERADO/SIERRA 1500 & 2020+ HD - 529005 from PUTCO to see if I could make it work. I plugged into the separate reverse plug for power and ground from the 4 pin flat plug. The lights work in reverse only right now or when I hit the unlock on the key fob. I will dig into it more eventually to see how I can steal power for when I use the cargo light switch. Thanks for all the help.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
