In the video linked below you can hear a chirp when I start my truck. I never hear it except during startup. I crawled all around and I can't pinpoint the sound. Any ideas??
On 8/21/2020 at 7:13 AM, silveradosid said:
have you check the valve in the exhaust system
I held it open while cranking the truck and I still heard the sound. Appeared to be from the front of the vehicle. Thats about as close as I can pin point it.
    Gkistler
    Gkistler
  • Who's Online   1 Member, 0 Anonymous, 881 Guests (See full list)
