I've never heard of a new designed valve cover.  I will try the original first.  The cam lope is a degree or two off. Do I just tell the computer tuner this. Does it make a difference in the way it drives?
   The broken manifold bolt stuck in the head did not go like planned.  The extractor chuck thing snapped it off flush. So I started drilling. Now I've drilled it out almost to size but it's off center. Only thing I can think of would be a dremel to grind.
      Turns out this is common and they make a clamp. So I'm just gonna put one of those on there.     I got a gasket kit and bolts from toms auto on ebay.  It took a while. I'll be putting it all together soon. Cleaning everything is a pain.
A machine shop can get it out, make the hole straight, and if necessary, use a HeliCoil to restore the threads stronger than original.  The new design cover reduces oil consumption through the intake manifold, moves the hole to a different place allowing less oil to enter the PCV system.  Give the tuner as much information as possible, though I'm not sure what you mean by cam lope other than sounds, but I think you may mean how the camshaft was degreed.
At first I thought I could do it without taking out the engine.   You pretty much have to remove the engine. What a pain in the ass.
So, just trying to make sense of all this.
Can understand pulling the motor if  a member is unsure of an engine's integrity.  Not exactly sure why someone would remove this one, though. Not enough information has been shared.  Surely, a buggered hole on one head would not be enough reason to resort to this extreme measure.
Hard to believe that anyone who can pull an engine like that would need anyone else's help.
Edited by GhostWriter
I couldn't get the timing chain to line up right with the peg in the camshaft.  And the oil pump was in the way. How do you get the oil pump off?   It's easier this way .
I'm starting to think this truck had an oil consumption problem from the first owner.  I was planning on putting the oil deflector thing on in the oil pan but it already has one.   I thought 2009 didn't come with it. I pulled the oil pan off and there was a lot of  sludge on the very bottom by the drain hole.  I drilled out the rivets on the gasket.
While you're in there you can remove the oil pressure relief valve right there on the oil filter housing part. Put a plug in it's place and you'll gain 5-10psi of oil pressure.
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
