Recently installed the Airaid 200-985 Modular Intake tube and a JLT Performance catch can. My truck is a 2019 5.3L LD. I am posting here because it is pretty much identical to the 2018. The 2019 mods forum is all about the new body style and engine bay.
For the record I did not install the intake tube because I expected big gains in power or mileage, but because I like the way it looks and sounds. Installed one on my 2010 4.8L and really liked it. I did enjoy seeing a dyno test on American Trucks YouTube channel which showed a 28 hp gain between 3-3500 rpm.
The tube is a piece of cake (POC) to install and comes with factory OEM type connectors where the hoses connect to the valve covers. BTW the hoses are pre-cut so POC.
I installed a catch can because it seems like a good idea. I read all the pros and cons and looked at several manufacturers. I chose the JLT catch can because I like where it mounts, the mounting hardware, and that it comes with pre-cut hoses and OEM style fittings where hoses connect to the engine. The fittings at the can are installed by JLT. Lastly, I like the way it looks. Takes minutes to install.
I have not checked the catch can yet as have only had it installed about 1500 miles. As far as the intake, it seems to have more power when accelerating. Might be all in my head, but hey, perception is reality! I drive on the interstate a lot and for distances of several 100 miles at a clip. I have 12K on the truck and have never gotten the average fuel use reading below 20.2 mpg. After the intake install it went to 20.3 on the first interstate trip. Not much but it certainly does not get less mileage.
I highly recommend the Airaid 200-985 intake and the JLT Catch can 3085D.
Selo
Looks great! On my 2016 5.3 I had to empty my elite catch can every 2500 miles, and yours looks about the same size. I was amazed how much oil it caught.
Sent from my SM-N970U using Tapatalk
Hi Jake,
Thanks for the info. I probably should take a look at the can reservoir real soon. I need to get a feel for how often I need to empty it.
Cheers,
Selo
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
