There are two different vibration events that I'm trying to sort out on my 2011 1500 LTZ 5.3 4x4. Truck has 190,000 miles and has been well maintained following the factory service schedule.
The first is when I apply very light throttle at 30-45 mph. The truck acts like it is lugging in 6th gear then it behaves fine once the transmission kicks down. Is this AFM related or a transmission issue?
The second is more of a pulsating vibration at around 65 mph. The vibration comes and goes about once per second and doesn't seem noticeable above 70 mph. Not a constant vibration like what an unbalanced wheel feels like.
Any advice?
Both kinda sound torque converter related.
If you got 190,000 miles from the stock 6L80e and converter, you did well.
I've also noticed when I cold start and shift from park to drive the truck tends to lurch forward slightly, unless I'm firmly pressing the brake pedal. Not sure if that's normal or a possible torque converter issue as well.
Any advice?
Assuming you have 3.42 gears, at 30 mph your still in 5th gear until right before 40 mph.  On mine the rpms are around 1000, no more AFM on mine.
The other could be tires need balancing or maybe it's time to open the rear cover and inspect the ring and pinion and spider gears.
Both issues are still present after switching to new tires and wheels.
Are you saying the low speed vibration is or is not AFM related?
Doubt it has anything to do with AFM, check your differentials.  Including the front mounts for it which also wear out.  The best part of my BlackBear tune is how the transmission performs now, no lugging.  Mine also has rhythmic noises which I attribute to my front differential, either the ring and pinion or the bearings on either side.  It's loudest in the 40s.
Edited by swathdiver
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
