Does anyone have any advice where to start looking for a P0300?
Truck has LM7 with 188k on the clock. Runs fine until it starts to warm up or going up a grade and starts missing and spitting. Things I've replaced over the last year,  throttle body, maf, map, cats and all o2 sensors, plugs and wires. Replaced coils 2 years ago. Fuel pump was just replaced with a delphi, check engine light would go on and it would spit and sputter, wouldn't start one day so changed the pump and it started but still spits and sputters when its under a heavy load.
Haven't changed the cam or crank position sensor, pedal assembly, intake gaskets or injectors.
Its giving me a flashing p0300 when going uphill but them it turns off when I'm back on level ground and no extra stress is on the motor. Passed smog like a champ 4 months ago. No clue what could be going on.
Get a live data scan tool on the truck to see exactly what cylinder(s) are misfiring. That will make it far easier to track down what to look at.
It could be just one cylinder or an entire bank of cylinders but it's hard to say right now.
+1
Misfire counter shows its all over. Sometimes it doesn't start and takes 2 or 3 tries to get it going. Also I noticed the Delphi pump I pump in it has a working pressure of 54psi and the spec on these trucks is 55 to 62. Could that be a possible culprit? I checked pressure while the line was primed and am only get about 50psi. Maybe a bad pump?
The pressure is fine, it's not low enough to be an issue. You'd have issues if the pump could barely even do 45-50psi while running and under load.
    • Starting at 17 running parts for my father’s construction business to haul our equipment. Eventually doing shows, sales and training after purchase. I drove a minimum of 50K miles a year. Half hauling something. After retiring 30K miles a year to the last 2 years 15K miles a year. 2/3rds highway driving. The major contribution to fatigue for me is from anticipation and awareness. I just don’t relax. Too many idiots on the road. There’s two kinds. The group that never leave the left lane tied together afraid to let anyone in doing 80. They’re mostly on weekends. Then the left lane sleepers usually next to a tractor trailer not advancing. Eventually the tractor trailer will drift over the sleeper will wake up. The train moves and the tailgaters who are usually mad as hell. You definitely don’t want to mix with them. The tail wagging bumper puller’s with under powered trucks are holding the tractor trailer up. That bunch are dangerous. I usually pace ahead all that. Unless there’s a gap when I can chill and let the speeders pass. I tried all different types of driving. I stay to the right except to pass, it’s the law that’s getting in forced more now because of road rage. I was so happy when my wife didn’t want to do the camping life. I had enough of pulling for work. The family has a bus and fifth wheel. I haven’t driven either one since retiring. No thanks.
    • Yesterday a suggested youtube video thumbnail caught my attention so I watched through it and it was a bunch of short clips someone gathered together of people pulling trailers, a lot of them were bumper pull holiday trailers and a pickup or suv pulling it. a few fifth wheels as well, some motorhome crashes also. The tail wagging the dog theme was quite evident in numerous self inflicted accidents that took out vehicles around them sometimes in the process as the unit finally swung around and flipped over in the middle of the highway. Or the other classic which literally could be called "I forgot the trailer was back there" in passing another vehicle on a multi lane one way freeway and then cutting back in line before the back of the rv trailer had passed the front of the passed vehicle and often in front of a tractor trailer and that never ended well. Or the wide kick out swing of the rear of a long travel trailer as they have so much overhang behind the axles and the trailer smashes into the side of vehicles in the next lane over ( typically sharp turns in city driving ). It makes one leery for good reason to be near an RV trailer after watching a video like that and be it on the highway, in town, or at a gas station where that rear end comes swinging around due to the fuel station being so cramped and not intended for larger trailers. I wonder how many officers have heard those words though "I forgot it was back there" as they investigate the accident LOL.
    • $5.10 for regular at the Kroger   It's been 6 months... is this the "new normal" ?
    • Just because a person can buy a travel trailer or a motorhome doesn't mean they can drive it properly. My observation during my RVing years.
    • The cure for facism. https://imgur.com/gallery/cure-fascism-9DH3bHs
